P1717 code on 2007 TL
Old May 5, 2026 | 12:38 AM
TGMX's Avatar
3rd Gear
Sometimes, if I switch from neutral or park to drive, the check engine light will turn on and the D will start flashing. However, the flashing D will go away after next startup and the check engine light just goes away a bit after that. I'm not sure if its the park neutral switch that is at fault or if it is just because I have some other weird electrical issue, since sometimes the "tighten fuel cap" light will come on and go away in a very similar manner, but this is new.
Any tips on what to test to see what I need to replace / check?
154206 miles.
Old May 5, 2026 | 02:43 PM
vpasla1's Avatar
Likely contacts are worn and now intermittent contact causing the issue.
Best bet would be to replace.
https://acurazine.com/forums/3g-tl-p...7-code-968913/
There's two links to threads in there to reference as well.
Old May 5, 2026 | 03:21 PM
TGMX's Avatar
3rd Gear
Thanks.
SaetypeS
Jul 16, 2022 03:49 AM
Aaron Dosentcare
Jul 16, 2017 09:26 AM
Omar Quiroa
1G RDX (2007-2012)
May 10, 2017 07:43 AM
Keanu's mrs. T
1/2G MDX (2001-2013)
29
Jul 6, 2016 07:02 PM
tufino1128
Apr 1, 2011 11:13 PM
