P1054 code
Acura Member
P1054 code
Hey guys, my 2006 TL just threw a P1054 code today. I looked up the code and it seems like it has something to do with the APP sensor. Yesterday I tightened up with cable running to throttle body to improve throttle response cause the cable had quite a bit a slack. I wouldn't say I tightened it enough to cause a problem though. This past weekend I also cleaned out the throttle body and replaced the intake hose. Do any of you think this could be causing the problem or is there something else? The code mentioned a BBV sensor but I'm not sure what that is
Acura Member
So I pulled a dumb dumb and didn't even read the code description on scanner before I googled the case. The description says "O2 sensor circuit no activity detected Bank 2 Sensor 1". I'm assuming I need to check the wiring around the O2 sensor and may have to replace the O2 sensor. I was doing some research and found out that our cars have an upstream and downstream sensor? Not sure which one I would need to replace though
Acura Member
Thanks for the info man! Just started my car again and it threw a second code.... P2247. Another 02 sensor related code
Acura Member
![](https://cimg7.ibsrv.net/gimg/acurazine.com-vbulletin/2000x971/20180918_185316_3ecfa0d1daedfc84da0b1d418a2281bb949abd60.jpg)
piggydog
02-11-2010 11:05 AM
jnherdendorf
2G CL Problems & Fixes
14
12-10-2009 08:42 AM
aznriceball
1G TSX Problems & Fixes
08-18-2009 10:15 PM
TLMAK
02-19-2008 03:59 PM
tsxnation
04-19-2007 03:30 PM
