p0712 p0175 codes help
Old Oct 28, 2016 | 07:53 PM
Elroja93's Avatar
hi u guys doing i just did a head gasket job with all oem parts spark plugs water pump timing belt thermostat coolant seals everything oem now when i turn my car is giving me this codes i just gor the car from shop today and when i check the enginei it seeing like am missing a bolt on front cats could this be the problem... that i got a leak by the front cat or should i be worry for anything else???
Old Oct 28, 2016 | 08:34 PM
Oh Sickest TL's Avatar
Jeff
inspect all vacuum lines and hoses to make sure they are connected to the intake etc. or you could have a bad o2 sensor.
Im not sure if missing a nut on there would cause the system to have a leak or not?
Old Oct 29, 2016 | 07:23 PM
Elroja93's Avatar
i did check all vacum amd hoses all of them are ok the only error i seen right now is the missing bolt i go to three different auto parts and non couldnt tell me when to find it and i dont feel like going to acura dealership for that but it seeing like i dont have a other choice
Jbaum
2G RDX Problems & Fixes
Feb 20, 2024 07:27 PM
ssgnco
4G TL Problems & Fixes
Oct 17, 2016 07:24 AM
AcuraOwnr956
Aug 25, 2016 09:31 AM
SuperGreg
Jun 10, 2016 08:02 PM
mattyacura
Jan 25, 2016 06:00 PM
