P0300 update ECM/PCM
Old Jan 31, 2020 | 02:26 PM
dpgrnprl3rdgen's Avatar
I just stumbled across a new issue on my 04 tl 5at with 198k miles, the issue being at higher rpm the car misfires, all cylinders misfire except cylinder 6, all 6 of my ignition coils, spark plugs are brand new and are oem parts, my valves are adjusted and I cleaned my egr not long ago, on shop key I came across a tsb that described my exact issue and it says that I need to update the ecm/pcm with the hds problem being is that I do not have one of those. Just wondering if there is anther known way to update the ECM/PCM without the hds or will I have to take my first trip to the stealership, any input would be greatly appreciated, thank you.
Old Feb 2, 2020 | 06:54 AM
Turbonut's Avatar
If the car has been fine all these years don't believe the update will help.
Usually the 300 series is a problem that affects all cylinders, e.g. vacuum leak, egr, fuel pressure just to name a few.
Old Aug 17, 2020 | 09:45 PM
Wdp_3g's Avatar
Did you ever end up doing it having similar problems right now
scribo
Jan 17, 2009 01:02 PM
joka
1G CL Problems & Fixes
Apr 17, 2008 08:04 AM
orgnlprankster7
Apr 10, 2007 01:30 PM
jayo_75287
Aug 18, 2004 11:03 AM
