p0141 heater malfunction
Old Jul 16, 2011 | 04:57 PM
kevin2488's Avatar
7th Gear
I have a customers 04 tl check engine light p0141 heater 02 sensor mal function b1 s2 ,checked resistance on sensor was high out of spec,replaced sensor ,drove 2miles code returned,checked power& ground up to 02 sensor has no ground ,swapped known good pcm,drove 5 miles code still there ,any ideas ,Im clueless ,gotta be a harness??anyone ran into this before ,if so what was the fix ?
Old Jul 17, 2011 | 10:50 AM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Did you try running the codes again.. it might be a different code, that happen to me recently.. it was the wrong bank well i changed the wrong bank..
Old Jul 17, 2011 | 01:09 PM
I hate cars's Avatar
Luckily the secondary 02s don't affect the way the car runs. I wonder what the odds are of some of the wiring/connectors and the 02 being bad... Assuming you checked the right sensor, since it's a circuit code you might start at the 02 connector and work your way back. Check grounds also.
Old Jul 18, 2011 | 04:37 AM
kevin2488's Avatar
7th Gear
ya I did same code& I know I changed the correct sensor ,checked the resistince again on the old sensor saturday morning still is out of spec so I think im halfway there ,called techline also gave me some ideas but never have run into this that the know of ,need to spend more time on it thanks for the advice
Old Jul 18, 2011 | 04:45 AM
kevin2488's Avatar
7th Gear
gotta be a wiring issue I have no ground to my heater sensor but the car does run like shit because the pcm commands the heater on until the car is warm to bring it to close loop,then takes away the ground when the loop is closed ,checked resistince again on the old sensor it is still high so I have a bad sensor need to dig into it more ,also called techline nobody has ran into this before except 1 car that the know of & that was a bad pcm which I already tryed I wish it was I we be done already thanks for your tip
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
07Acuradude
Sep 29, 2015 03:01 PM
