p0141 heater malfunction
I have a customers 04 tl check engine light p0141 heater 02 sensor mal function b1 s2 ,checked resistance on sensor was high out of spec,replaced sensor ,drove 2miles code returned,checked power& ground up to 02 sensor has no ground ,swapped known good pcm,drove 5 miles code still there ,any ideas ,Im clueless ,gotta be a harness??anyone ran into this before ,if so what was the fix ?
Luckily the secondary 02s don't affect the way the car runs. I wonder what the odds are of some of the wiring/connectors and the 02 being bad... Assuming you checked the right sensor, since it's a circuit code you might start at the 02 connector and work your way back. Check grounds also.
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
