Oxygen sensors please help!!!!!!!!!!!!!
Old Mar 13, 2015 | 10:21 AM
kevins2004tl's Avatar
2004 acura tl codes are po135 and po155 changed both oxygen sensors still have codes showing disconected battery still shows codes please help
Old Mar 13, 2015 | 11:08 AM
Any info
Old Mar 13, 2015 | 11:09 AM
replace o2 sensors?
Old Mar 13, 2015 | 11:13 AM
i replaced both o2 sensors still get code
Old Mar 13, 2015 | 12:18 PM
polobunny's Avatar
Registered Bunny
Clear the code?
Old Mar 13, 2015 | 12:32 PM
i did still comes back
Old Mar 13, 2015 | 03:26 PM
Has this happened to anybody else
Old Mar 13, 2015 | 03:37 PM
polobunny's Avatar
Registered Bunny
If I was you I'd post one more time in your thread within a 3 hours gap, it seems to be working so far.
In other words, patience.
Old Mar 13, 2015 | 03:57 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
May not be the sensors and as you have already figured out by replacing them, still have the code. So in your case, it wasn't the sensors.
Possible causes
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
The code means that there is a problem with the heater element circuit of the heated oxygen sensor. The control module monitors how long it take the sensor to warm up and start sending an adequate signal. The code is triggered when the sensor is taking too long to warm up. Water getting inside the heated oxygen sensor connector can cause the heated oxygen sensor fuse to blow. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. If the sensor and connector are OK, replacing the O2 Sensor 1 usually takes care of the problem
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
