over 50 MPH Vibrations
My 04' TL is ratteling like you would not beileve. I pulled over because I thought I had a flat tire. I did not.
Some things to take into consideration, I did drive in some very deep snow yesterday and I have recently installed new tires.
The tires have not made any additional noise untill yesterday so I do not think that is the cause.
Could I have damageeed somthing driving trough 15 inches of snow?
If so where should I start looking?
'10 Hyundai Genesis Coupe
OR just like a batch of snow caught between the treads best idea is to have your rear tires on dry road and your front tires on a slippery road, snow or water, something slick. Lift the parking break put it into drive and floor it and give it gas in moderate amounts to keep it bouncing from 4~6K rpms, it should cause the tires to smoke and melt whatever is on off. Or you can drive it off tires should build up heat slowly.
ust to ask the obivious, did you get the tires balanced properly on a hunter roadforce PRO machine???
And if you have had them properly balanced (per csmeance) check to make sure you haven't lost any counter weights, it's very rare but I've seen it happen twice this winter on similar rims (in Calgary), apparently from road salt followed by freeze/thaw. Could be an easy fix before you go smokin your tires (what's the temp where you're at anyhow?). I can't answer my bumper colour issues, but hopefully this helps.
The noise went away due to a nice thaw.
We had a helluva lot of snow this past week. Smoe towns got 29.5 inches in 1 day.
I recently bought blizack snow tires at "Discount Tire Company" so I assumed that they balanced them when the installed the tires.
I can't bieleve it was ice all along. Well that was easy.
Thanks for taking the time to post guys.
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
