Outdoor temp gauge not working help!!!
Old May 14, 2009 | 09:42 AM
WB56-TL's Avatar
Need some help. I have a 2005 Acura TL that the out door temp gauge is coming up ---...
Any word of advice?
Old May 14, 2009 | 09:49 AM
LoveMyTL-S's Avatar
3G garage is your friend:
https://acurazine.com/forums/3g-tl-problems-fixes-114/has-anyone-had-outside-temp-display-go-flatline-558081/
Old May 14, 2009 | 11:05 AM
SouthernBoy's Avatar
Registered Member
Yes. Fix this as soon as possible. Otherwise if you don't use your car for 5+ days, you will have a dead battery. There are two ways to handle this.
Locate number 7 fuse and remove it for many 10 seconds (I think it's number 7 - check this out in the writeups I did in the August/September '04 time frame). If this is not the correct fuse, just remove the positive battery cable from its post for around the same amount of time (have your codes handy when you do this). Then start the engine and see if you get a reading.
01CLOwner
Oct 9, 2015 01:07 PM
acurajj
Sep 19, 2015 03:47 PM
NSolace
Sep 3, 2015 08:02 PM
dlknight
Sep 3, 2015 07:54 PM
