Oil pump leak and thicker oil?
I recently was told by my dealer that I have a oil pump leak. I was quoted around $1000 to fix, which I cant really afford to fix for a few years. At my next oil change, I was thinking of running a slightly thicker oil to maybe slow the leak? I'm currently running the manual recommended 5W-20 in Mobil 1 extended performance, was thinking of switching to a 10W-30 in the same brand. Good idea or no? I know I'd probably sacrifice a some gas mileage. But would I theoretically suffer some other negative effects from running the thicker oil? I'd hate to cause some premature damage to the oil pump or something else because the car wasn't designed to run the slightly thicker oil. Or would the safer bet to be just to run the manual recommended weight and keep an eye on my oil level?
Shouldn't be a problem to run thicker oil but I don't think it will help TOO much either . A leak will leak..
you can try running a 5W-30 first and see how it does. How many miles are on your TL? You can save a ton on labor if you get the oil pump leak fixed at the same time you do the timing belt service!
Is the leak leaving any drops on the pavement after sitting overnight? If not, don't worry about it.
I've got 104K on my recently purchased TL type S, about two weeks ago I had the timing belt job done at the Honda dealership and they didn't say anything about the oil pump leak. Then two days ago I got the valves adjusted and spark plugs replaced at the Acura dealership because I had a service coupon, and that's when they let me know about the oil pump leak and how much cheaper it would have been to fix if the Honda dealer let me know about it at the time of the timing belt job Needless to say the Honda dealership lost my business.
Sounds like a typical Acura stealership scam job. Those types of leaks are not uncommon in our cars, but It probably isn't a real issue. Most likely, if it does even exist, it can wait until your next TB job. Like I said, if it's not leaving oil on the floor after sitting overnight, it's nothing to worry about.
My "oil" leak was discovered by my Acura dealer less than a year after I had my timing belt done at my local Honda dealer. However.....Acura made it quite clear that there was a leak, but it isn't bad yet and it isn't worth the investment to repair at this time. Until it is actually dripping off the engine making a mess...I don't care about it. There are some honest dealers out there guys. My Acura dealer has only once tried to push things and that was the first time I sent my wife in. I had a nice chat with the service advisor and they have been absolutely respectful since then....yes I know, I shouldn't have even had to do that...but I write that off as one advisor there sucked, while the rest have been a pleasure to deal with mostly.
In your case, I would for sure have a talk with your Honda dealership. That is something they for sure should have noticed and at least mentioned to you. If mine had been 2 weeks vs 10 months, I would have for sure called the dealer back.
My dealer wanted to charge me $1200 for the re-seal and $1350 to replace the oil pump. I didn't really notice an oil spot where I parked but I had it replaced anyway. Still waiting for my loyalty points to show up from that job.
The DVD-A Script Guy
This may not be a popular opinion but I'd clean the underside of the motor of all the oil and just stick a disposable foil oven liner under it (assuming it's garaged so no wind to blow it away) and watch it for a week or two. A drop here or there simply isn't worth getting all upset about. I wouldn't bother changing oil viscosity either. Or maybe just find an indy mech to do the work much cheaper than a dealer if it really bothers you so much. (if we knew what area you are from someone could probably suggest one) If me and an older car with >100K I know I'd use the oven liner and call it a day. Been there, done that, with an old Saab.
I'm gonna go duck know before someone throws garbage at me
