Oil leak
Old 10-27-2022 | 12:54 PM
ShadowVampyre's Avatar
Oil leak
My son has a 2006 TL, he has it for about 8-9 months. It came from a friend who is a part time mechanic and had done some top end engine work done.
Anyhow it has an oil leak that seems a bit worse. I cleaned the underside of the car to try to find the source.
I see the oil dripping from the oil pan drain plug, and was hoping just a loose bolt or bad gasket. It seems that is just the low point. It seems to be coming up higher. I have attempted to point this out in the video link shown.
https://1drv.ms/v/s!AsLhh64kMYgjhN4APnP0Dqt5-ati7g
https://1drv.ms/v/s!AsLhh64kMYgjhN1_wI7mIKX0GfI30A
Then another leak on the other side, looks like a leak perhaps at the seam. See video link.
The car also had an overheat issue, that in another thread.
Any ideas?
Thanks in advance
Old 10-27-2022 | 01:19 PM
how's the valve cover gasket?
Old 10-27-2022 | 01:31 PM
Will have to check when I get home from travel tomorrow.
the guy I bought it from had the head gasket removed and resurfaced, and I assumed ( ouch) this would have been addressed
Old 10-27-2022 | 05:27 PM
Canadiandemon's Avatar
Had the same problem and noticed it went all the way to the oil drain plug. Traced it to the pcv valve leaking through the gasket. Replaced the pcv valve below the oil dipstick and problem has been resolved since.
ShadowVampyre (10-27-2022)
Old 01-27-2023 | 10:40 AM
jtenorioyyc's Avatar
3rd Gear
Had the same issue exactly as what you have on your videos last year. Found out it was the gasket on the oil pump, a very time consuming job. Had it replaced and never seen that oil leak returned.
mellowcream
1G RL (1996-2004)
11-08-2020 12:03 AM
E39
08-30-2020 11:49 PM
Aleax
09-11-2015 11:31 AM
Warren803
01-25-2011 12:34 PM
larryd
11-16-2006 01:19 PM
Quick Reply: Oil leak
