Oil Drain Washer Size
Old Sep 10, 2009 | 08:58 PM
zsameer's Avatar
What size is the oil drain washer? Is it the same as the atf plug washer? I have replaced the ATF fluid and i beleive that was 18mm washer. I just got 10 washers from acura of peoria and they are smaller than the ATF drain plug washer. are they different sizes? Havent done an oil change yet on the car and wondering if i got the correct washer from the dealer. I got these from an ebay auction. Thanks.
Old Sep 10, 2009 | 09:50 PM
zsameer's Avatar
Ok so i found this .... can someone confirm this? #23 in the pic.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
023 94109-14000 WASHER, DRAIN PLUG (14MM) 1 2005TL
Old Sep 11, 2009 | 02:30 AM
libert69's Avatar
18psi
sorry this doesnt answer your question about size, but you can use the same washer again and again
Old Sep 11, 2009 | 08:31 AM
LoveMyTL-S's Avatar
I did this so I don't have to worry about a plug or washer:
https://acurazine.com/forums/3g-tl-2004-2008-93/ez-drain-704203/
And in the diagram you provided, part 23 is the washer you want. Very cheap at your local dealer.
Old Sep 11, 2009 | 08:36 AM
Bearcat94's Avatar
AZ Community Team
You can, but you're not supposed to. You buy a nice car and then you're going to cheap out on a $0.35 washer?
If you go to Honda-Acura Accessories, you can get a six pack of Filters and Washers at a reasonable price:
http://www.handa-accessories.com/tl.html - near the bottom of the page.
Old Sep 11, 2009 | 09:41 AM
blkaspec's Avatar
Full of water...
great link, thanks!
thegipper
Oct 21, 2015 07:19 AM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
coykiam
Sep 11, 2015 03:43 PM
