Oil Drain Washer Size
What size is the oil drain washer? Is it the same as the atf plug washer? I have replaced the ATF fluid and i beleive that was 18mm washer. I just got 10 washers from acura of peoria and they are smaller than the ATF drain plug washer. are they different sizes? Havent done an oil change yet on the car and wondering if i got the correct washer from the dealer. I got these from an ebay auction. Thanks.
Ok so i found this .... can someone confirm this? #23 in the pic.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
023 94109-14000 WASHER, DRAIN PLUG (14MM) 1 2005TL
I did this so I don't have to worry about a plug or washer:
https://acurazine.com/forums/3g-tl-2004-2008-93/ez-drain-704203/
And in the diagram you provided, part 23 is the washer you want. Very cheap at your local dealer.
If you go to Honda-Acura Accessories, you can get a six pack of Filters and Washers at a reasonable price:
http://www.handa-accessories.com/tl.html - near the bottom of the page.
great link, thanks!
Mugen TSX
Eastern Canada
Sep 16, 2015 09:52 PM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:05 PM
