Occasional choppy.....
If not, the fluid should probably be changed out. Honda has new transmission fluid that's supposed to be good. If you want to go aftermarket to something better, redline D4 is fluid is an amazing option.
Thanks for the reply. No it shifts smoothly up and down. it doesnt slip or anything. It's just that sometimes when coming to a stop the shift from 4 to 3 or 3 to 2 isn't as smooth. I'll do the tranny fluid change. Where can I get that fluid? Thanks again
Check this post similar to you problem
https://acurazine.com/forums/3g-tl-2004-2008-93/07-tl-type-s-harsh-downshift-875291/
Grade logic transmission?? mine does the same.
https://acurazine.com/forums/showthread.php?t=875291
Thanks again man. Much appreciated.
tman570
Jun 11, 2019 07:56 AM
dainmezron
Oct 16, 2015 06:56 PM
