This is normal?
Old Jan 23, 2015 | 01:18 PM
iiamchili's Avatar
This is normal?
Hey ziner!
I was looking around at my engine bay and i saw this hose with oil on it this is the steering hydraulic hose i think? Trynna figure if this is normal or i need to replace it or any opinion?? Thanks
Btw i got an 05 base auto 95k.
Old Jan 23, 2015 | 01:44 PM
polobunny's Avatar
Registered Bunny
No that's not normal, yes it's PS fluid most likely since it's the PS hose.
Also you should probably change the accessory belt eventually, looks a bit tired.
Old Jan 23, 2015 | 01:49 PM
anytime you see a leak, its not normal.
Old Jan 23, 2015 | 03:47 PM
iiamchili's Avatar
Ok thanks any idea was causing this ?
Old Jan 23, 2015 | 05:05 PM
Turbonut's Avatar
Clean area with brake clean, then squeeze and rotate clamp to another spot.
Keep an eye on the area and if it still leaks you'll need to look into hose replacement.
Old Jan 23, 2015 | 05:18 PM
truonghthe's Avatar
looks like the hose is dry and crack over time which cause it to leak.
Old Jan 23, 2015 | 07:12 PM
iiamchili's Avatar
Ok thanks im going to do that
Old Jan 23, 2015 | 07:13 PM
iiamchili's Avatar
Im try wat turbo said if it continues the ima replase the hose
Old Jan 24, 2015 | 05:37 PM
WanaBeFaster's Avatar
Acura Technician
replace the hose and the o-ring that's in the black outlet.
Old Jan 26, 2015 | 04:59 PM
iiamchili's Avatar
Old Jan 27, 2015 | 08:20 AM
ZOMGVTEK's Avatar
Is that drive belt factory?
Old Jan 28, 2015 | 05:28 PM
iiamchili's Avatar
No idea i bought it with it but i just bought a new one installing this week, and soon doing the timing belt
Old Feb 4, 2015 | 08:43 PM
olorin's Avatar
There was a recall on TL leaking power steering hoses -- the leaked fluid damages other things eventually.
I believe the replacement hoses are steel braided.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rockyboy
Oct 2, 2015 10:45 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
