Noise while driving in snow
Old Dec 27, 2010 | 03:00 PM
Tsx02905's Avatar
So we got about 10-15" of snow and my car sucks already got stuck 4 times
But that's not the problem .... I'm getting a noise like if I have bad balljoints,links or maybe is just the snow if anyone could be of some help and tell if they ever had the same thing going on ... Thanks
Old Dec 27, 2010 | 03:02 PM
AMUA6's Avatar
ScoobyZINE
It's a car, not a tractor.. bro lol It's probably the snow crunching underneath your tires.
Old Dec 27, 2010 | 03:57 PM
I hate cars's Avatar
Traction control, stability control, or ABS. Do you turn the TCS off when driving in snow?
Electronics get you stuck in slippery conditions. I disable ABS and turn TCS off.
Old Dec 27, 2010 | 06:40 PM
Tsx02905's Avatar
So now I notice it even on clean roads when I go over bumps I recently had my wheel bearings done the same time I change brake pad and rotor. Is it possible that the knuckle assembly isn't tightened right .... Idk just wondering
Old Dec 28, 2010 | 02:30 PM
Tsx02905's Avatar
Does anyone know if sawy bar links and bushing are a common issue for 3 gen tls ?
Old Dec 28, 2010 | 04:54 PM
Whdrms's Avatar
e92TL
dito, i turn off traction when i get stuck, cus that prevents my wheels from spinning continuously
but how do u turn of abs? is it something u gotta reach under hood and plug off something?
Old Dec 28, 2010 | 05:31 PM
I pull the fuse. I've only done it a couple times for testing when I was trying to see if I could beat the ECU by measuring stopping distances on dry pavement.
Old Jan 1, 2011 | 09:20 AM
Whdrms's Avatar
e92TL
oohhh i see
Old Jan 1, 2011 | 09:31 AM
NJ SHAWD's Avatar
Back From The dead
Chances are there is still snow pushed up under the car. If it has been cold, what's there wouldnt melt.
Old Jan 1, 2011 | 03:50 PM
Tsx02905's Avatar
The sound is coming from the left side and the snow is almost gone it was like near 60 degrees 2 day
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
MyGuti
Sep 12, 2015 06:52 PM
jliu6789
Sep 8, 2015 08:02 PM
dlknight
Sep 3, 2015 07:54 PM
