Noise from underneath
Old Feb 23, 2009 | 09:33 PM
akash4u's Avatar
When I leave my car for a whole day/night, start it up and drive-and-turn or reverse-at-an-angle..I hear a one-time noise from underneath the car.
I would position the noise source to be towards the driver side but not right below the drivers-seat. Maybe between the seat and the front bumper.
It doesnt happen everyday..but at least 3-4 times a week.
Its a 2005 TL and has 43K on it. Its been 3-4 weeks since I bought it.
Old Feb 24, 2009 | 09:50 AM
akash4u's Avatar
Does anyone else have this issue? I'm wondering if this is the same topic as described in here :
https://acurazine.com/forums/3g-tl-2004-2008-93/does-anyone-else-get-click-noise-when-3g-garage-004-a-552426/
Old Feb 24, 2009 | 11:41 AM
Tripnbeats's Avatar
check your motor mounts maybe one is knocking as the torque is applied....is it stick or auto???
Old Feb 24, 2009 | 02:20 PM
Majofo's Avatar
not specific enough.. could be mounts, CV joints, tranny, wheel hub, brakes..
describe the noise as best you can. Try to reproduce it as best you can and tell us specifically, like... Is it only when the car is cold?? Give us the outside temp.. Does it only make noise on full tilt turns?? Is the sound is a creak, whine, knock, grinding???.. Can only hear it driving and not while it's idling??.
Old Feb 24, 2009 | 03:52 PM
akash4u's Avatar
Frequency : Only once a day and not every day. Sometimes in the morning and sometimes in the evening.
Temperature : Less than 20F
Speed : I would start my car and just turn and be at 0-10MPH
Description : The moment I make the turn..I hear a noise like someone hit my chasis with a little hammer (from underneath). Feels like the noise comes from somewhere closer to the driver side than to the passenger side. It doesnt matter which side I turn.
Its been cold all thru Feb and I've had the TL for about 3 weeks so far..so I did not have a warm day yet..to prove that the weather has part in this.
Old Feb 24, 2009 | 03:55 PM
akash4u's Avatar
I dont hear it while driving or idling or even while making regular turns. It only happens the first time I turn. And again Like I said above..its not everyday.
Old Feb 24, 2009 | 03:56 PM
akash4u's Avatar
Its Automatic
Old Feb 24, 2009 | 03:58 PM
Majofo's Avatar
That doesn't sound good. I'd get your ball joints and cv joints checked out asap. Otherwise it's coming from your steering column / rack.. which sounds more like the immediate culprit. Any noticeable difference in steering?
Old Feb 24, 2009 | 05:47 PM
akash4u's Avatar
I can steer fine it drives very smooth.
The dealership is looking at my rattles tomorrow. I will have them inspect for anything weird/obvious.
Old Feb 24, 2009 | 06:10 PM
Majofo's Avatar
Well before you drive over there.. when you get to your car, rotate your wheel dead right and move forward a little bit.. listen for metal grinding / creaking. Then go reverse and move back a little bit and listen.. do the same on a full dead left turn. If you hear metal grinding then that could indicate your cv joint/s are going, but if there is no leaking or the boots are not damaged then it could just be the cold weather is hardening your boot grease. The boot grease is designed for high temps not low temps. From what I could find the spec rating for boot grease is around 0-5F, so in the low temps it can harden and may make the CV joint 'creak' when cold, but should go away when warm. So do the test on a cold start in cold temps.. then try again after driving a while.
Old Feb 24, 2009 | 06:33 PM
akash4u's Avatar
Allright. Will do that first. I wonder if the CV joints can give away so early but not sure how the previous owner drove it.
Tomorrow is a warmer day here so I should be able to run the warm test.
Old Feb 24, 2009 | 09:27 PM
ssmtl2nv's Avatar
2009 g37s 6mt
The tl makes weird noises in cold weather.... And oem mounts are known to fail and make noises...
Old Feb 24, 2009 | 11:04 PM
csmeance's Avatar
park your car outside on the street and in the morning, first start of the day, pull out of space at less than 5 MPH. Pay attention at 10, and 20 MPH. Do you hear the noise? Does the brake pedal feel slightly odd? This is the ABS self check clunk/flap/flutter that is normal with the TL.
Old Feb 25, 2009 | 10:56 AM
Tripnbeats's Avatar
do u feel anything in ur feet or in ur steering wheel when this occurs?
Old Feb 25, 2009 | 02:57 PM
georgegiorgio's Avatar
G Force
I have similar problem.
Whenever I want to leave from a parking spot, especially if I haven't drove the car for a few hours, and if it's cold outside, and I'll turn my wheels all the way, like locking angle, and reserve, and that's when I hear a clicking clicking weird sound coming out from the wheels.
And there's a feeling like the wheels are going over bumps.
However, the surface of the floor is flat.
Have any of you guys notice this before?
This started just recently, before Thanksgiving '08.
By the way, mine it's a CBP 07 TL-S, automatic.
Never happened before.
Old Feb 25, 2009 | 10:46 PM
akash4u's Avatar
georgegiorgio - Thanks for the description. Thats exactly how it happens on my TL.
BTW - I got my car back, from the dealer, today. They were supposed to fix my rattles and the burned out bulb on the heated-seats switch.
Guess what. After keeping (or working on) my car from 8AM-5:30PM..I find out the the dash rattles have become worse and the guy did not do a good job aligning the Alumimium trim. Did a screwy job overall.
I talked with the manager and he asked me to come back tomorrow and promised good results. Lets see.
Old Feb 25, 2009 | 11:24 PM
G Force
I know rattles
I know rattles coming from underneath the steering-wheel.
I took my TL-S and have the dealer put a special tape fixing the rattle coming between the plastic and the metal.
However, the B Pillar rattle need to replace something that the dealer are out of stock.
Trust me, you gotta bring your TL to the dealer and have them work with detail, and test drive several time.
I know some TL has driver-side-vent rattle, mine doesn't have it, but I still told them to put those special tapes just in case.
But, one possible rattle from the center speaker area, I haven't told them to put those tapes, cuz, I wouldn't want them to remove too many parts, besides, I don't have those rattle.
Old Feb 26, 2009 | 12:09 AM
akash4u's Avatar
I am totally disappointed with the work they did today. I hope they fix it in the next few tries. Else I will go some place else.
Old Feb 26, 2009 | 07:46 AM
Tripnbeats's Avatar
George...it sounds like your axles... could be a bad hub bearing as well.
Old Feb 26, 2009 | 05:45 PM
PeterUbers's Avatar
cv joints, time for a new axle
Old Feb 27, 2009 | 08:26 AM
Tripnbeats's Avatar
yea def along the lines.... a friend of mine had a similar issue on an 06 maxima.... hed hit his brake the car would be fine...on take off the car would knock...so i looked saw a damaged CV and blow bearing...the plastic seal that holds the packed grease was almost all melted upwards....thats the type of shit that sucks....but now to the OP since those parts are broken lets say... have the motor mounts n tranny mounts checked....
Old Feb 28, 2009 | 06:41 PM
akash4u's Avatar
Had 2-3 "not so cold" days in Cincinnati and I havent felt the noise I was referencing in the first post. But I will get my axles checked on Wednesday next.
Old Feb 28, 2009 | 09:14 PM
BLACKURA_NY's Avatar
I have car ADD
um... the ABS system usually makes a "bang. thud" sound when you first begin to drive the car.... its normal... especially when you are backing out of your driveway.. i heard it all the time on my UA6... not so much on the type-s
Old Mar 1, 2009 | 02:32 AM
Majofo's Avatar
I'd wait til it warms up. It could just be your CV boot grease becoming stiff in the cold weather. Wait til mid-March / April, when it warms up, and see if the problem persists.
Old Mar 1, 2009 | 12:15 PM
ssmtl2nv's Avatar
2009 g37s 6mt
+1 on my ua6
Old Mar 1, 2009 | 02:18 PM
Kennedy's Avatar
OMGWTF4THGENTL
That's not your ABS.
That's your rear brake pads being stuck to the rotor becasue the tension applied via the e-brake.
I left my TL for 3 weeks after a little slush driving in the winter. When I pulled away, I left a 2 inch skidmark becasue the rears brake were locked so hard.
Old Mar 1, 2009 | 05:55 PM
sebounet2005's Avatar
TL 2012 SH-AWD TECH/UMBER
I have exactly the same noise on my 2007. Since the beginning. I have it for 2 years now, and here in canada it's cold. So if i let the car few hours in cold temperature, i never put the e-brake. I can hear the noise you describe, for me it looks like an abs check thing , but due to cold weather you hear it more or the noise seem special.
Old Mar 5, 2009 | 08:38 PM
t0talacuratl's Avatar
Green Machine
I have a similar problem as the OP. At cold starts, I hear knocking noise as soon as I make a left or right turn. After it warms up, I don't hear it anymore.
This started happening as soon as the cold weather came around. Are you guys sure it's the cv joint grease? Should I get this checked out by the dealer?
Note: I have innovative motor mounts.
Old Mar 6, 2009 | 09:39 AM
Tripnbeats's Avatar
kennedy... yes n no i know what ur talkin about but black is correct there is a prep the car goes through when you start to drive up to 10mph....it just feels like a pump working and making noise for 2-3secs in your brake pedal.... sometimes u notice it sometimes you dont....ever since the original TL came out my friend had it and i had the 99 and 03 and now the 05 they all do the same thing with the ABS.
Old Mar 6, 2009 | 12:35 PM
akash4u's Avatar
Had the dealer check this issue yesterday and they found nothing.
Probably because they could not reproduce it. Its been warm here this week and I havent seen that noise come back.
Old May 1, 2009 | 12:30 AM
MokaYoka's Avatar
hi all..i think my is the same problem, it's like chirping noise coming out from front driver side. someone said might be the loose bolts...
Old May 1, 2009 | 09:40 AM
Majofo's Avatar
loose bolts? probably not.. chirping from the driver's side? are you sure and not the passenger side?
Give us all the details when & where.. yr & miles.. how long and when you first started noticing.. etc..
Old May 2, 2009 | 12:00 AM
MokaYoka's Avatar
hi Majofo, i hv a 07 tl-s about 14600 miles. the chirping noise i hear was from front driver side tire, but i asked my friend to check and couldn't locate the problem. this noise would occur when i close my driver door or when you push car up and down. i would be appriciated if you hv any suggestions.
Old May 2, 2009 | 12:07 AM
I have car ADD
ahhhh i've gotten that sound before.... on both my OEM suspension and my Tein coilovers... it only makes that noise on humid/wet days....
Old May 2, 2009 | 09:40 PM
MokaYoka's Avatar
i hear the noise right after few miles after I cruise the vehicle no matter is wet or dry.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
