No Start
No Start
I have an 04 5AT that worked yesterday and won't start today. It's strange because when I turn on the key to the 1st and 2nd positions, all of the lights on the dash go on, every option in the car works, but the starter is not turning at all. When I turn the key to the start position, all I get is silence.
I checked most of the fuses both inside and outside the car, and they all seem good. Any ideas?
I guess I should have mentioned that the battery is new and everything electrical on the car seems to work. The only thing that doesn't work is when I turn the key to the start position, I get nothing from the starter. And yes, I do realize that it could be...the starter, but I wanted to see if anyone has seen a different cause for this.
Ok, I did a little research on AZ and it seems like I should be checking my connections to the starter. If that doesn't pan out, I am going to remove the starter and have it tested. Does this sound like the right approach to take?
justnspace (06-28-2013)
Registered but harmless
Received 1,150 Likes
After checking the connections and before taking the starter out, try hitting/striking the starter when the car fails to start. If it starts then, your starter is on its way out.
If you wish to test your own battery, yourself, try this link - or remove it and have it tested at Sears, any auto store, etc.:
https://acurazine.com/forums/showthread.php?t=890429
no start no click? check your solenoid wire and relay.
Just as a final wrap up, I took the starer to the auto parts store to be tested. The starter was so weak that the counter guy could stop it with his hand. I installed a new one, and am good to go. Thanks for all of the input everyone!
That counter guy is pretty ballsy (or stupid) grabbing a starter drive with a bare hand and power applied to it.
But seriously, how do you hook-up the starter, so that it can pull the required amps? I have never seen a test station for a starter, so do you use jumper cables and a regular car battery? because if not, the starter will not pull the normal amount of power, since it is not really trying to turn an engine. Just wondering if the described test, was a valid test - so that I will know how it should be done if I ever need my own starter tested.
MMkay.
He was wearing a glove?
I work at NAPA and we have a machine to test them. They don't drive a flywheel or anything but it does give you total amperage draw of the starter. Not a good mechanical test but 90% of the time if they are bad you can tell right away. I've even seen one start on fire. There is still now way I would grab a drive end with or without a glove on.
Yeah, I was pretty shocked when the guy put his hands on! Like the last 2 posters said, the counter guy looked up my year, make, and model, got a code and typed it into the testing machine. It is supposed to exactly match the requirements of the starter for that car. He also tested the new starter before I took it home to make sure that it was good.
Re-manufactured would be a good way to go. No matter where you buy the starter its probably going to be rebuilt by BBB Cardone Industries. Not always, but they rebuild a lot of them and for the most part they are very reliable.
rockyboy
08-04-2024 10:35 AM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
