No power at all please help
In the last few days I have installed my aem v2 cia and coils went to fire the car up and nothing. I threw a battery charger on nothing. Tried to jump it nothing. Not even a light tries to turn on. Does anyone have an idea what I am looking for? I have a 2004 6mt. I am rather worried I messed something up. If you have any idea I'll try everything.
So you have NO power at all? That is odd... I am sure you verified your battery terminals are correct. Hope nothing got fried.. Check for blown fuses as well. Could have very well blown one when trying to jump it.
That one contains the major ones that would be associated.
I would have the main fuses tested
Also you could check to see if you blew your ground
Also your positive cable maybe corroded down the line
I don't have alot of experience with electrical, just some of the first things that pop into my head. Goodluck and I hope you figure it out!
Fuses should be checked with a voltmeter (MM) for continuity at the test points on the top. Check cables on battery and if the ground connection was removed to install the CAI, was it reconnected securely?
Acura604
20
Aug 5, 2017 12:55 AM
