No Power to AC Compressor
I got an '04 TL with no AC. I brought the car to my mechanic who checked the fuses and said they were okay. He replaced a switch that turns on the compressor but still no luck. No power is getting to the compressor. Does anyone know what the problem could be?
thanks guys
thanks guys
Did he check the refrigerant charge? If the system has leaked then the compressor won't be enabled so you won't see any voltage at the compressor clutch. It's to keep you from damaging your compressor in the event you lose too much refrigerant.
Bad compressor clutch field coil?
Read this thread to the end. A DIY is linked at the end if needed:
https://acurazine.com/forums/3g-tl-problems-fixes-114/c-relay-assembly-770494/
Acura604
20
Aug 5, 2017 12:55 AM
