No hot air
Old Dec 12, 2012 | 10:58 AM
06TLASM's Avatar
No hot air
car only blows out cool/cold air. No heat. outside temp sensor still works. What should I check for? any idea?
Old Dec 12, 2012 | 12:15 PM
Undying Dreams's Avatar
Trying letting the car warm up and then put the temp to "Hi". If it starts blowing hot, you can adjust it down accordingly.
Old Dec 13, 2012 | 10:40 AM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Your resistor has probably gone bad. Its right under your glove box.. I had similar issue last year. I think its called heater blower resistor. GL.
Old Dec 17, 2012 | 05:49 PM
06TLASM's Avatar
Thanks! This did the trick. However, when I put it back in Auto mode, no hot air again. Pretty frustrating!
Old Dec 17, 2012 | 05:50 PM
06TLASM's Avatar
Do you know how much it costs to fix this?
Old Dec 18, 2012 | 01:43 AM
wareagle19o9's Avatar
Pretty easy to do. I just ordered the part yesterday for mine through Advance Auto $45.99
Old Dec 18, 2012 | 03:08 AM
NC916's Avatar
can you provide the part number? autozone and oriely like $80+ for the heater blower resistor.
for the OP mines does the same thing as yours, just dont use auto thats what I do. I feel like the pin that changes the temperature behind the firewall is off because I have to put it to at least 82+ for it to start blowing hot air. Even at 80 degrees it blows cold air still even after cars warmed up.
Old Dec 18, 2012 | 11:52 AM
06TLASM's Avatar
Hey, can you do a detailed write-up, with pictures preferably, when you fix yours?
Old Dec 19, 2012 | 12:00 AM
[quote=NC916;14219118]can you provide the part number? autozone and oriely like $80+ for the heater blower resistor.
Part number is RU1041 and it's 45.99 and if you order from Advance Auto online I believe you 20% off.
I will be changing out the part tomorrow and I will be sure to take pictures and do a write-up.
Mine only works sometimes but it only works when my air is on high so I'm hoping this solves my issue.
Old Dec 20, 2012 | 01:21 AM
Solved my issue. Car is blowing air now. Seriously easiest thing i have done to a car. Pop out the black plastic cover under the glovebox and the resistor is right infront of you. Was held in by two phillips head/10mm screws. Unclipped it the clipped in new one and reinstalled. Took all of 5 minutes.
Old Dec 20, 2012 | 07:24 PM
NC916's Avatar
thanks for the part number and update, will do this when I have time.
SidhuSaaB
May 30, 2020 12:40 AM
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
hashbrown
Sep 29, 2015 12:13 PM
