No cruise control
Old Sep 5, 2021 | 07:59 AM
056mt's Avatar
No cruise control
A while back I had to raise the engine a bit while working on it. I used the hanger on the passenger side, and looped a tie down strap around the intake manifold where it connects to the throttle body on the driver side. Loosened the engine mounts and lifted a few inches. Got it all back together and cruise control does not work. The steering wheel button will turn the light on the dash on/off but cruise control just doesn't work. I replaced the throttle body with a junkyard pull, replaced the APP sensor/assembly (also junkyard pull) and checked all related fuses but it still doesn't work.
Any ideas what the problem could be?
Old Sep 6, 2021 | 06:15 AM
Try checking the #8 pedal stopper pad for the #6 stop & cruise switch assembly on the link below:
Pedal for 2005 Acura TL | Acura OEM Parts
Old Sep 6, 2021 | 03:25 PM
056mt's Avatar
Everything appears to be normal. Stoppers not missing and switch appears to move normally.
Acuratl3535
Feb 1, 2017 02:50 PM
Kwizzle
2G CL Problems & Fixes
Jul 6, 2016 09:49 PM
Crazy88
Sep 3, 2006 03:39 PM
mmaaxx
Apr 1, 2006 12:50 PM
Chief F1 Fan
Dec 8, 2005 11:35 AM
