No air - passenger side A/C vents
My Garage not
after i replaced my cd changer there's now no air out of the two right side ac vents for the passenger side. anyone know if it's just one of those white plastic hoses that needs to be reconnected and where it's at behind the dash? i'm trying to pinpoint it to try and disassemble as little as possible.
I just went though a similar problem, but mine was no heat from the drivers side. There are about 4 different mix doors behind the dash. One controls the defrost/vent/floor, the other is for hot or cool air, and one on each side (I think) for passenger/driver side temps. Does it not blow any air at all out of the passenger center dash vent and the far side passenger dash vent, but it does form the defroster and floor vents? If so remove the glove box and plastic piece behind it and look at the two small square black motors that control the doors for the vents. Have a friend change the controls to see which one doesnt turn and that is the problem. If you remove the upper center dash vent piece you can look down into the vents and see the doors moving...
Oct 21, 2015 11:38 PM
sockr1
Oct 1, 2015 01:31 AM
sputik
Sep 7, 2015 01:40 PM
