No air blowing through A/C
Today I got in my car and noticed that no air was blowing through the vents. I tried turning the fan speed all the way up and nothing is coming out at all. Turned the A/C off and no change, turned the temp all the way down and all the way up but get nothing. I did notice that the fan in the front next to the radiator isn't moving at all.
Any suggestions on what could be the problem?
Im gen2 so we may differ-
if there are 2 fans behind the radiator:
the passenger side one is tied to the ac compressor On
If its not running with the ac set to ON- there is a switch signal problem
driver side rad fan is temp controlled by a sensor in radiator
we (gen2) have a prob with the connector to blower motor burning the wire and resistor
Try looking under edge of dash at glovebox- can you see the connector wire- power lead to cabin fan?
if not - remove glovebox as in cabin air filter replacement- then you can access the blower motor and wires
If not fuses and it does not blow when you select the heater, the next most likely thing is the power transistor or the blower motor.
thanks for the diagnostic sheet nfn- you rock!!
Im gen2 owner and can only guess our problems followed for a few years
with summer and many using 5 on the fan speed for long periods, you get that burnt connector
gen2 has an update kit so should be same for you- 20 bucks at dealer
longer wires and new connector eases strain and fits tighter
Use `electric contact grease` inside the fitting on install- 1 dollar packs at parts store counter- coat the metal prongs
Biggie_B
02-26-2017 11:14 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
