New HFL unit and still have problems
Old Oct 4, 2013 | 02:53 PM
tonto340's Avatar
I had the infamous "Booting Up" error for my Handsfree link. Also the diagnostic screen (Guide, Menu and Cancel) showed red for HFL. I installed a new HFL unit today. The diagnostics screen shows that it is good (it's green) but I'm getting a "No Information available" in the gauge screen. Does anyone have any ideas what I need to do next?
Old Oct 4, 2013 | 02:57 PM
hard ECU reset? battery pull?
Old Oct 4, 2013 | 03:00 PM
uninstall then reinstall!?
Old Oct 4, 2013 | 06:05 PM
Will Y.'s Avatar
Registered but harmless
Have you started the HFL setup to pair a phone yet?
If not, start with "set up" to pair a phone.
If yes, what happens?
Old Oct 4, 2013 | 08:12 PM
tonto340's Avatar
I pulled the negative cable for 30 minutes; that didn't help. I tried re-installing; that didn't help. When I give the command "phone setup:, it does nothing.
Old Oct 4, 2013 | 09:32 PM
Will Y.'s Avatar
When you push on the HFL activation switch, does it generate a beep?
If yes, say "system" and follow the prompts which follow.
If no, check to make sure the HFL connector is securely plugged in-- remove the HFL bezel, then unplug and reconnect the HFL.
Old Oct 5, 2013 | 12:44 PM
tonto340's Avatar
Yes, the system generates a beep. When I say "system" it goes to screen setup. If I say "phone setup" it does nothing.
Old Oct 5, 2013 | 08:07 PM
Will Y.'s Avatar
Good-- that means the HFL is working.
Once you say "system," the HFL should respond with "options are 'setup' and 'clear'" before it starts to guide you through the phone pairing process.
See page 195+ of your owner's manual, or in the on-line owner's manual at: http://techinfo.honda.com/rjanisis/p...707O00189A.pdf .
Old Oct 6, 2013 | 02:06 PM
tonto340's Avatar
Will Y: thank you for trying but so far nothing has worked. When I push the TALK button I get a beep and system performs commands for the nav, radio and A/C but not the phone. When I say "System" it goes to screen setup. If I say "phone setup" it does nothing. According to the diags screen the HFL unit is good; it's just not registering with the system.
Old Oct 6, 2013 | 05:18 PM
Will Y.'s Avatar
Silly question, but are you pushing the talk button for the Navi or the HFL?
The reason I ask is because Navi voice command will activate the screen setup, but not phone setup, on my 2005.
The Navi voice command switches are adjacent to the HFL switches, but each switch is independent and controls only one system or the other.
Old Oct 7, 2013 | 04:22 PM
tonto340's Avatar
It turns out it wasn't a silly question. Thank you for asking the right one. Now I feel like an idiot.
Old Oct 7, 2013 | 04:45 PM
Slpr04UA6's Avatar
-------Tim-------
^We all make mistakes! Glad it wasn't a bigger problem!
I don't have Navi......
Old Oct 7, 2013 | 05:32 PM
Will Y.'s Avatar
You aren't an idiot because you can now talk hands-free, unlike the idiots who are driving around holding their phones to their heads.
Old Oct 8, 2013 | 06:58 AM
Will Y. always to the rescue!!!!!!!!
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Markbby06
Sep 17, 2015 02:30 PM
