New to the forum: Discovered missing bolt?
Greetings
I purchased a 2008 TL in June of this year with only 12,000 miles. Overall I really enjoy the car, my only complaint is the transmission doesn't feel as fluid as it should. (no slipping or major problems just the timing is a bit off) I have been reading through some transmission threads and decided to do the 3x3 flush today with dw1 and I completed that O.K.
I received the parts I ordered for the 3rd and 4th gear pressure switch install. I started on this and ran into a couple of problems and something very interesting
1. I am having a bit of trouble removing the wiring harness behind the driver's side wheel. I have 2 of the 3 clips removed it is the uppermost clip that does not want to come out and I don't want to break anything.
2. After successfully changing the sensor at the back of the motor I moved on to the one below the airbox. After removing the airbox I was looking for the pressure switch when I discovered there is a bolt and washer missing. (In Photo).
Is anything connected to this?
Where does this cavity lead?
Your help is appreciated
You have tranny problems at 12K? Highly unlikely. Ever owned a V6 Honda/Acura before? Their trannys are different than others. I wouldn't be pissing money away on switch replacing.
Do the drain and fill, but likely needs an ECM reset and be driven.
Thank you
Yes I Will go to the dealership when they open.
Iv'e put 10,000 miles on the car since I bought it so It can't be hurting it too bad. I was just asking before I got it all buttoned up thats all.
Cheers
Go B-more!!!
Cheers
Go B-more!!!
LOL they do have tranny problems!
the switches go out, like what we have been documenting here on acurazine....
Went to the dealer today and spoke to a mechanic and he said that there is nothing mounted there not even a bolt but there is on older models.
I finished changing the switches yesterday
First impression the transmission feels good. It shifts through a little tighter instead of the slight slip. Of course this could relate to the fluid change. The used z1 was dark and a bit thick at 22,000 miles, magnet showed normal signs of wear. Anyhow I'm happy with the outcome and I will keep an eye on the fluid(change it before factory spec) or change brands time will tell. Thats all for now.
blacktsxwagon
Oct 27, 2015 10:12 PM
dainmezron
Oct 16, 2015 06:56 PM
