New Acura HID Bulbs... one is yellow now!
This has been an ongoing 6 month issue. While still under warranty, the dealer agreed to replace both headlight bulbs (have a friend who works there... helped a brother out). Ever since, the passanger side bulb has been yellowish with no problems on the driver side. You can see the yellow by looking at it directly and at its projection when pulling up to the garage door/wall. They have now replaced the bulb 3 times (part # 33116-SLO-003), put in a new ballast, and just put in an entire new headlight assembly... still yellow. They called Acura corporate and they have no solution either. They told me today that I have to live with it. This is my last stop before putting it up for sale. I can't keep a car with a problem "that can't be fixed"... drives me f-ing crazy! Let me know if you have had this same problem and was it ever fixed. THANKS!
that acura dealership is pretty stupid...
New bulbs are going to be yellow for the first 100 hours of use. During and after this period they will turn whiter and bluer. The bulbs needs 100 hours of use to colorshift or for the color to burn into the bulb. It's completely normal for new bulbs. As well they should have been smart enough to know that HID's need to be replaced in pairs.
just1nsama (12-03-2013)
wow, has anyone bothered to do a voltage check going into the ballast? if it is past 100 hours of use and it is still yellow, I'd start checking voltages and make sure they are where they are supposed to be.
Acura Cert MASTER TECH
OP - Along with voltage checks, a simple check could potentially swapping bulbs side to side, for either a short, or long period of time. I'm slightly inclined to say voltage may not be the issue because a lack of proper voltage, in my experience, causes either flickering/no operation. Was there any body work done in the past?
That said, I've never actually had this specific problem; the bulbs have always shifted after the expected time frame. The only thing I'm really going on is a loose ground after body repair (2G TL, caused flickering), and a bad alternator (2G TL) that caused loss of proper operating voltage at times (again, caused flickering and at times no operation).
Possible to supply pics for comparision? I still think swapping the bulbs, regardless of time frame, could assist in diag.
The original 2005 bulb Acura part number was 33115-S84-AO1 and the new one is 33116-SOL-003. Acura indicates they changed the bulb when the 2007 model headlight came out with daytime running lights, but still works on the 04-06 models.
Since they agreed to cover both lights under warranty, they replaced them both. The car has never been in an accident. I had both headlight assemblies replaced under warranty because they both had tiny cracks on the inside of the covers from something unknown to me or them... so the Acura district rep said to replace them. The light does not flicker at all. When I first turn it on the color matches, but in starts to get more and more yellow for the first 30 seconds and stays at that level. acuratech239... how can I get the driver side cover off and how can I check the ground on the pass side?
Micha - I think the OP is still having a problem with getting the driver's side cover off to access the bulb, hence why he hasn't swapped them yet as I suggested. That said -
OP - The driver's side is tougher to get the bulb out of, especially if you don't have a cold air intake. That said, it can be done with an OEM intake, without taking the bumper off and the headlight out. Sadly, there aren't really any tips I can give you other then as you realized, it's very tight fitting in there. If my memory serves me correctly, you don't actually remove the cover on that side, rather just move it as far out of the way as possible (which isn't much), to access and remove the bulb. You'll probably cut up your hands/wrists/arms a little bit in the process. Even someone like me with skinny arms has a little trouble with this. If I remember correctly, there should be a DIY for bulb change without bumper/headlight removal somewhere in the 3G forum. Worst case scenario, remove the bumper and headlights as needed Hope this helps, and keep us posted.
I used to go in behind the driver side fender liner but it just lead to fustration and scratched up arms and hands. It would take me an hour to remove one bulb but I found it easier and less time consuming to remove the front bumper. Now I can have the both headlights replaced and bumper back on in less 30 minutes. There is a youtube video on how to do it.
Well... I took my time and got the bulbs swapped without removing the bumper or anything. It was a bitch and my hands and arms show it. Guess what... they are BOTH the same color yellow now!!! I wonder if the ballast or ignitor is destroying the bulb. This would explain why when the dealer swapped the ballast and put in the OLD light to test it, it was still yellow. Whatever it is, when the bulb turns yellow... it stays yellow. I can't find anything on the internet to back this up so the dealer will think I am crazy even though my friend works there. I am going to give it a week and see what happens. This sucks! :thumbsdow I would post a picture from my computer but I'm a dumb ass and don't know how.
I put 2 pics in my album under YELLOW HID's... doesn't show the yellow very well in the pics though.
^ I know for a fact I did not touch the good bulb I took from the driver side and moved to the passanger side.
Any comments or suggestions now??? I put 5 pics in my album now that show the yellow light(s).
this is a interesting thread! I have a 08 TL and have had no problems with the OEM Xenon's up till about 2 weeks ago; I too have begun to notice when pulling into the garage or looking at the Xenon's when on that the passenger side has turned a yellowish color while the driver side has remained normal!
I might have to take it in and have the voltage checked! This is really ridiculous considering the car is only 1.5 years old.
I gave up last month. They are both a tint of yellow and I will have to live with it until I get rig of it at the end of the summer. I am sick of driving a FWD car anyway... AWD is next. Post what the dealer does for you though.
Same problem now
Hello I have the same problem the first driver's side bulb appeared pink i ask myself, 'll change bulbs. I went to the dealer I bought 2 bulbs later, i change removing the bumper myself everything was fine until the 2 bulbs look yellow was the truth I wonder how I could fix this problem. HATE seeing my car like this
oem bulbs are supposed to be a little yellow
and if you really hate yellow, just buy an aftermarket 5000k bulb. such a simple and cheap solution
killer8rican (12-04-2013)
basically the old bulbs were white 5000k, the rason that i replace one was the bulb turn pink but the other was perfect. the dealer recommended replacement 2 bulbs. after the change are now yellow. when I see another Acura tl there not the same look
