The never ending noise chasing
Old Aug 9, 2024 | 01:45 PM
arcticbluealex's Avatar
4th Gear
This is the last of my long list of noises to alleviate on this TL. Sending good karma to whoever can help or lead to a solution.
VIDEO
https://youtu.be/_fNkcXAzg_g?si=ZNnqlx0OKVQ8fzQA
ISSUE:
Upon idle when warm a noise develops (whine/whistle/unsure what it's called), stethoscope shows noise is loudest around intake manifold valleys on either side of the black denso valve/sensor on the passenger side of the Intake Manifold.
TEMP FIX
Pulling the dipstick immediately quiets the noise for 10 seconds then it returns
REPLACED PARTS
Valve cover gaskets, all intake manifold gaskets, TB gasket, EGR gasket, pcv valve (honda), pcv lines (front/back), air filter.
[Unrelated] ps pump, ac compressor, belt tensioner, serpentine belt, belt tensioner.
SERVICES
Valve adjustment
Old Aug 20, 2024 | 02:52 PM
4th Gear
Problem was solved; Hole for PCV in intake hose was not drilled during manufacturing. Used a 7/16 drill bit and finished the job.
Old Aug 20, 2024 | 03:48 PM
twokexlv6coupe's Avatar
OEM Intake hose & tract? Seems weird that started happening 16-20 years after manufacturing.
Personally, I'm a fan of the BOV noise, it's just a bit of a PITA to actuate it.
Old Aug 20, 2024 | 04:08 PM
4th Gear
This has to be an aftermarket part, and who knows how long the previous owner had this happen. I'm just happy i found it, I'll stick to having the BOV type noises on the RSX.
Atanas Dimitrov
Mar 20, 2021 08:42 PM
jisleyjr
Jan 21, 2017 11:51 AM
Reedadam
Apr 30, 2015 08:21 PM
acupower
4G TL Problems & Fixes
Sep 22, 2014 08:12 AM
etxxz
Jan 10, 2009 09:17 AM
