need to replace back light on heat seat switch
The backlight on my heat seat does not light up anymore I took my car in for the power steering recall and got a estimate for the dealer and they wanted $122 to replace a bulb!!! WTH!! does anyone know the part number for that and know where i can get instruction on how to replace it?
any info will help!
thanks
any info will help!
thanks
I agree, $122 sounds like a rip just for a bulb, but that's primarily for labor due to the # of things they have to take apart to get to the damn switch.
Then bulb is in the switch. The dealer replaced my entire switch under warranty when my set heat light died because they said it easier just to replace the whole switch assembly. They said since the console assembly is 'opened up' to the extent it was, they just went ahead and replaced the other switch too while they were at it.
The light inside that switch doesn't use a bulb and I dont think you can easily replace it. You would rather replace the whole switch which is ~$17. This will work for 04-06 TL and not sure if 07-08 uses the same switches but you can search for them on the site if you have 07-08 TL.
Switch
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Assembly diagram and also can refer to driver's manual
Switch
You know i noticed my passenger side light is out aswell, not sure if it happened before or after i had USSpec unit installed.
Lol yeah 17 dollars for a whole switch sounds alot better than 122 for a bulb. Seems like an easy replace.
Switch
Switch
Some of my interior lights are out as well on my '04 and I have just under 50,000 miles. Strikes me as quite premature, but so far I have not bothered to do anything about it.
Switch
Switch
1. Remove #5 and #9 with a flat head, just pop them out, they are held on by clips.
2. Remove shift knob by untwisting it, remove shift boot (if car is manual), remove #6.
3. Unscrew all screws from panel #4 and remove.
4. Remove switch and replace.
accually remove #9 and #5 (boomerrages)
pop up the arm rest and remove the rubber pad at the bottom there will be two silver screws. remove them
remove srews #25 (gold) and 2 black screws behind it.
this will seperate the center arm res tand cup holder. just slide it the whole thing tords the back seat
the bulbs are easy to get and no f'n around the shift knob and lower pocket
the backlight is the middle one
then reverse
time 5 mins
then reverse
time 5 mins
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
