Need New Wheel Bearings
Old Nov 30, 2010 | 07:47 AM
S2000 GUY's Avatar
DMB!
Hi all,
I appreciate the look here, my other ride is an S2000 so I do most of my posting on S2KI, but always liked this community.
I have an 07 TL-S with A-spec 18” wheels on it. I have a “warble” sound from the front end, starts kind of rhythmic at low speed but above 50 mph it’s constant “moan”.
I’ve heard this sound come from tires that were “hammered” (still good on tread but worn out from the inside). I drive the car pretty hard and I’m wondering if the wheel bearing are gone.
Car has 75K miles, tires are Dunlop SP Sports and are at 75% tread, tires were just rotated and car was just aligned.
Thanks for the help
Old Nov 30, 2010 | 07:55 AM
I watched my neighbor change out a wheel bearing in an expedition.
he had the wheel off and let me listen to what a bad bearing sounded like.
Sounded like a grinding noise. I Immediately went to check mine. Very smooth and no noise.
Old Nov 30, 2010 | 08:13 AM
Opel's Avatar
Try wiggling the wheel while jacked up....any motion could be an indication of bearing going bad
Old Nov 30, 2010 | 08:31 AM
S2000 GUY's Avatar
DMB!
took it to my tire place for the work explained in my OP and they said the bearings were ok but the noise is still there, i assume they checked them, he treats me well.
Old Nov 30, 2010 | 08:41 AM
nfnsquared's Avatar
I doubt it's wheel bearings. Very rare on these cars. I'd suspect abnormal tire wear due to out of spec toe. Have your alignment checked.
Old Nov 30, 2010 | 09:13 AM
S2000 GUY's Avatar
DMB!
Allignment was checked and was slightly out, he said one tire had a bit of a feather edge on it but i've put enough milage on it that it shouldn't be an issue.
Old Nov 30, 2010 | 09:28 AM
nfnsquared's Avatar
If the tire is feathered, that's enough to cause the noise. Did you rotate the tires to see if the noise moves or goes away?
Old Nov 30, 2010 | 10:10 AM
S2000 GUY's Avatar
DMB!
I did and it got quieter but has not gone away. Car has around 600 miles since the rotation.
Old Nov 30, 2010 | 03:55 PM
BukvaMan's Avatar
I had the same noise on my rear left side and i thought it was the bearing but before replacing it i tried other things, like rotating tires and such but nothing helped. As soon as i replaced the wheel bearing, the noise went away.
Old Nov 30, 2010 | 04:30 PM
Comptechtl2367's Avatar
Sounds like tire noise to me. maybe get two new tires...
KB1_EJ6
Nov 13, 2016 09:51 PM
2012wagon
Sep 29, 2015 04:21 PM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
heyitsvic
Sep 4, 2015 09:38 AM
