Need new caliper - am I getting ripped off?
06 - 6MT w/ 75k miles
So I'm driving and suddenly I hear this somewhat loud, constant and intermittent screeching sound coming from my wheels. I find out it's my rear wheels that are screeching and so I take it to the dealer and they tell me I need a new rear brake caliper and pad. The pad had worn all the way down and made slight damage to the rotor, but it looks as thought the rotor isn't that bad and can be saved. They want to charge me $340 for the pad and caliper and labor. Is this a good price or can I get this done at a lower cost?
It can always be done at a lower cost than most any dealer, especially if you're going to do it yourself. If you see the rotor is grooved throw it away and a new one is in order along with the rear pads.
The caliper list is $165, pad set $62, total $227 so I guess labor is $113. Add a rotor $100 and the price is $440.
Using Rock Auto as an example, rebuilt loaded caliper $85, rotor $50 for $135 total or $305 savings.
Good idea to bleed the system after 3 years if you haven't and also be wary about the other calipers if one is contaminated.
The caliper probably could be rebuilt. Ask them.
The list price for a new caliper is $162. Pad set is $62. So, no, they are not overcharging for a dealer.
http://www.acurapartswarehouse.com/P...gPicture=False
the rears seem prone to contamination failure and corrossion pitting of the inner wall so it cant be rebuilt
cars on the east coast really seem to get moisture in the brake fluid,,
wiki hygroscopic to understand why
I have done gen3s with 2 years on them and crud was nasty grey!!
acura is liberal with that 3 years till first change,,I say 1 year then every year
prevents costly repairs
when a caliper is replaced the entire system does get flushed/burped so that is part of the labor time
when the caliper hangs partially on and you drive a few hours, smoke comes from the brake pad as its worn down to nothing- actual fire can result-
while the pad on other side of rotor is getting little or no pressure applied to it
they should be replacing the brake pads across both wheels,
you dont replace 1 pad or 1 side alone
always keep braking even
Turbonut and nfnsquared:
Thanks for the pricing information. It seems like the quote they gave me is within reason. I did not ask if it can be rebuilt but it seems like from what 01tl4tl stated, it's probably best to get a new one.
01tl4tl:
Thanks for the advice. I think I will call and have them replace the other pad. So you are suggesting as well to replace the brake fluid in the rear as well?
Also, thanks so much for the link to the parts. That will help me possibly negotiate the price of the service a bit .
01tl4tl:
Skillionare
Just buy the caliper, and the pads and put them on yourself. Takes about 30 minutes. When I did the legend caliper swap on my CL-S I just clamped the brake lines shut before removing the calipers then replaced them with new pads re-attached the lines then remove the pinch. Just be sure to pump your brakes rigorously before driving so they tighten up again. Or you can always bleed the brakes and do new fluid and still come out ahead of stealership pricing.
01tl4tl:
01tl4tl:
Check to see if the labor price includes the bleeding of all 4 wheels to remove the old fluid. The new caliper can be replaced and only that caliper needs to be bleed to complete the job.
They can be rebuilt rather inexpensiverly ($13 parts) and crocus cloth can be used on the bore with no problem, unless the bore is heavily pittted, which I doubt. Having said that, the dealership will not rebuild the caliper as it's too time consuming and the price of the rebuilding will probably cost as much as a new caliper.
On a side note, they gave me a 2011 TL as a loaner for the week. Very nice car, but still dislike the body styling and the fact there's no touch screen navigation any more . That stupid knob reminds me of my wife's BMW, which I hate. But still a nice ride .
xsilverhawkx
09-28-2015 06:51 PM
