Need helping reseting my OIL LIFE
Team AM #123
i just got an oil change today and i need to rest my oil life
i try searching and found this
https://acurazine.com/forums/showpos...73&postcount=4
but it didnt work
i held the button for 10 seconds and nothing change, no question was asked
any ideas??
but it didnt work
any ideas??
Registered User
very simple to do , i did it the other day after i changed my oil
close all your doors, press select till you see the oil life under the mileage
when u get there, hold the reset button until the service screen comes and says, press cancel or reset, press reset and you'll be back at 100%
Team AM #123
i did that, turn the car on
turn the MID to my oil life screen
held the reset button forever! a few times while i was doing that it return to the "Service due soon" screen
but never did i get a screen asking if i wanna reset or not
all doors were closed, car was in park
Here’s the full procedure to reset the MID display.
(The procedure on page 196 (of the 2004 owner's manual) of the manual is incorrect. In paragraph 3a of the manual, the requirement to hold the button for 10 seconds the second time it is pressed is omitted. If this is not done, the display will not reset.)
1. Turn the ignition switch to ON
2. Select Trip A or Trip B (You can use either one, so if you are using one to record data for something, use the other one to reset the Oil Life Indicator).
3. Press the < or > button repeatedly until the oil life is displayed.
4. Press and hold the Select/Reset button for 10 seconds. The Multi-Information Display will ask for a confirmation.
a. If you are sure you want to reset the display, press the Select/Reset button for 10 seconds again. (This is the part omitted from the manual.)
b. If you do not want to reset the display, press the < or > button to select “Cancel”
This will explain what happens to the other services items when you reset the MID before the service due message appears.
From the service manual, page 3-6:
So this means if you change your oil before the 15% Service Due Soon is displayed, and you go to reset the display, if there are other items to be serviced, they will show up on the display, and if you clear the display the MID will take this to mean that you performed the required service.
The statement from the service manual is a little vague, and I think they meant to say that if other items require service, the message "Service Due Soon" will be displayed, since if there is nothing else requiring service there would be no need for the message.
This information is NOT in the owners manual. At least it is not in the 2004 owners manual, which is what I have.
NOTE: If you are resetting the display when the oil life is more than 15%, the maintenance message "Service Due Soon" will be displayed. Make sure the maintenance items requiring service have been performed before resetting the display.
mada51589
05-03-2022 08:54 PM
IndycarFaster
09-11-2015 02:52 PM
