need help with zkws
Old Oct 11, 2008 | 08:48 PM
pearlite TL's Avatar
need help with zkws
I just installed zkw lenses and it seems like my low beams are too low and my high beems are too high.. is there a wrong way you can install these lenses?! I compared it with an 08 TSX and it seems like their lights are brighter.. whats the problem??
Old Oct 11, 2008 | 09:36 PM
csmeance's Avatar
did you use a spacer to fix the mis-alignment of the ZKW lense? I believe it has to be spaced 2mm forward...
Old Oct 11, 2008 | 10:25 PM
no i did not use a spacer. where do you get the spacer from]
Old Oct 12, 2008 | 09:12 PM
csmeance's Avatar
kennedy used a cd case cover (the clear plastic) and JNC uses some metal ones when he does headlights. I suggest you PM kennedy for more info.
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
eastcoastguy
Sep 24, 2015 02:07 PM
JnC
Sep 11, 2015 06:06 AM
JnC
Oct 17, 2010 06:08 PM
JnC
Mar 31, 2009 06:53 PM
