need help wiper fluid, turn signal not working etc.
Old Apr 23, 2014 | 12:22 AM
Fr3shAcuraTL's Avatar
Question need help wiper fluid, turn signal not working etc.
My turn signal, remote, high beam, wiper fluid, and wiper blades dont work on low..hazards work but turn signal doesnt. can someone help me figure this problem out. I checked some of the fuses and they seemed fine might be a relay idk.
This happened earlier wen i came out of work i had my car already on and i accidently turned the key whichmakes tgat weird noise on the starter 👎. Thats where i think the problem happended because it was working before. I disconnected my battery and will check in the morning if that changed anything.
Old Apr 23, 2014 | 09:21 AM
Vlad_Type_S's Avatar
Registered Bike Offender
Let us know if the problem is still there. Electrical problems usually have a common factor. Can you verify that the following things aren't working?
1) Left and Right turn signal
2) High Beam
3) Wiper Fluid
4) Wipers
5) Keyless Remote
Can you also confirm that everything else works? So your Low-Beams work okay? How about the fog lamps? And the wipers work only on the highest setting?
It sounds like there might be a problem in the under-dash control module. I'll need to look at the wiring diagrams later after you confirm the issues to see if we can find a common factor. Or maybe someone else has had this issue...
Old Apr 23, 2014 | 09:25 AM
Yes all those things u mentioned arent working. I just came back to my car and connected the battery because i left it disconnected over night and everything started working again.. but if u can find any way of fixing this i really appreciate it just in case it happens again
Old Apr 23, 2014 | 09:30 AM
Wipers only work on highest setting, low beams and fogs work as well.. just the ones you listed werent working
Old Apr 23, 2014 | 10:50 AM
Oh good. Well they say don't fix it if it ain't broke. So let us know if it comes back.
csmeance
Jan 7, 2026 06:25 PM
mada51589
Jan 9, 2025 04:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
