NEED HELP... Thanks 3gTL
I have an 06 Acura TL base auto navi... im having soo many issues and im almost bout ready to sell it but i dont want to reason being is im going to give it too my moms but dont wanna give her it messed up it has 190k ive done everything ive possible can from all oem honda parts waterpump, hydro tensioner, pulley thing, spark plugs twice smh:/, coil packs, timing belt, serpentine also... thermestat ... always changed oil with mobile one ep and trannsmission with acura fuilds and coolant also
My egr valve
All oem as stated but
One thing i didnt use oem was the starter & brand new yellow top optima
But im having a weird start up like it turns and doesnt wanna turn over but after it does and has a bad start im guessing its an emissions or something else ive given up and anything would help
Check engine light pulls p0300 multi misfire and also 3 valve codes think was 301 303 305 but like stated i did do the valve adjustment
Car has a awkawd smell from exhaust and im losing coolant but no leaks ive changed the heater core valve where it was leaking but im lost should just fix her shes cherry still
My egr valve
bad starter..
justnspace (08-29-2016)
sounds like your cat is going out too.. Maybe the backpressure of the cat clogged is making it hard to start the car.
you ninja-edited that into the OP so i didn't read that at first.
yeah... in socal, probably stay away from that. Just put WTB for a cat in the Black Market. I'm sure people have some lying around from when they switched
clogged cat sometimes results in misfires too can't it?
awkward smell from exhaust led me to cat. loosing coolant sounds like head gasket is going.. is your oil milky?
Americandream
05-30-2016 10:35 PM
