need help, fried wire maybe?
Old Feb 11, 2013 | 01:16 AM
NC916's Avatar
Hey guys I was installing the tablet on my car everything was working well, after I cut the wires from the 4 plugs behind the HVAC to extend it. After I did that I installed it into the car plugged in everything to test and I notice that when I open the door the lights dont turn on and where you turn the left side of the steering wheel to turn on the headlights doesnt work either. My key fob dont work doesnt even respond to lock or unlock. I am able to start the car and when I do the headlights turns on, radio works but the screen doesn't and the controls for it doesnt work either. So I was looking for some suggestions what can I done wrong? did I fry a wire or something.
Any help would be great.
Old Feb 11, 2013 | 04:28 AM
05_NBP_TL's Avatar
HE>i
look over your work. With all the problems your noticing, it sounds like something has been left unhooked, or shorted. Make sure your connections are good, and the the extended wires are paired correctly at both ends. did you leave anything disconnected?
hope you can get this figured out. I had a similar instance where i was doing my audio build and disconnected my ACC fuse #32 (and forgot about it). When i finish my build, I started my car and my radio wasnt working, my car wouldnt go in gear, etc..
Old Feb 11, 2013 | 03:48 PM
NC916's Avatar
oh man I found it, never knew back up fuse caused all this to go out. I unplugged every fuse but back up fuse man I feel stupid. now everything works perfectly thanks.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
