Need help asap- Check engine light/VSA on...reduced power
Hi guys I figured I would start a new post on this as my other thread titel didnt apply any longer.
As I was driving home last night my check engine light and vsa light were on the whole time. I drove about 35 miles like this. It seems my car will not rev above 2000 RPM's and fortunatley I was able to coast in neutral most of the way ( I have a 6 speed). Based upon my search it seems my APP sensor may be bad. I have a few questions--
1)Is it safe to drive my car in this condition ? I mean it accelerates REALLY slow and all but I would like to drive it to the local autozone to get the code.
2) The acura dealer told me its possible autozone may erase the error code if they go to check it...is there some way to avoid that ?
3) Ultimately the acura dealer is going to fix my car---should I just take it directly to them ? Also is a part like the APP sensor usually available same day ?
4) My acura dealer is far away...can someone else--like a honda dealer fix this problem ?
I know I can order this online and maybe fix myself but this is my daily commuter and only car so I cant wait days and days for a part to arrive, I need the car now.
Thank you in advance guys...this messageboard is a great resource
Registered Member
Your car went into a "limp home mode". The codes can be read with a hand held tool (I have one) without erasing them unless you want them erased. Get this fixed ASAP. If you are out of warranty, there's no reason a quality shop can't do the repair for you. As for an Acura of Honda dealer's shop, they should have this part in their inventory.
I had the same issue this week, thought my car wouldn't make it home on my 50 mile commute. Don't get an APP, it's not the problem.
Solution: Go to the gas station, fill 'er up, tighten your gas cap (twist 3 times/'til you think you're gonna break it).
The next day, the VSA didn't come on, and the day after that, the CEL went off. No issues since. It explains why this issue has come and gone over the past year..it's a user error.
Have the codes pulled and double-check them to verify the error. There's only a handful of bad lights that can come on in your car but 100 ways in which the ECU can be triggered to turn them on.
Did you ever get your problem fixed?
My 2007 TL is doing the exact same thing. VSA and Engine lights pop on and car goes into VSA mode, where pushing the gas pedal is almost useless until I can pull over and restart the engine. Pulled code (P0848) at AutoZone, they say "failed APP sensor". This happened to me 4 times this morning.
Gillman Acura in Houston told me the sensor that tells the car the position of the gas pedal is malfunctioning and needs to be replaced. Price quoted to fix is just under $400.00.
Good luck
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
