need help
Old Jun 13, 2010 | 02:06 AM
lextl2006's Avatar
need help
my 06 tl automatic makes a clicking noise sounds like its from front left tire when i turn the wheel or hit a bump any help?
AckTL05's Avatar
Former Sponsor
Your axels are cracked. I have been through about 4 sets so far. Mostly from excessive wheel hop/take off or a lot of bumpy roads.
Old Jun 13, 2010 | 06:26 AM
Pharonocon's Avatar
Whoa. Axles crack that easy? That scares me.
Old Jun 13, 2010 | 12:02 PM
01tl4tl's Avatar
I think he means cv joints are done- at least one is and you replace the entire axle unit with 2 new joints/bearings with new boots on them and a new axle shaft
if you abuse the car doing burnouts or hit a lot of potholes that eats those bearings
Its about the most common part wearout on fwd cars~
1 hour labor to replace
also ck the ball joints and sway bar end links
Have a local shop-brake and suspension shop look at it
NOT a big brand name place with corp office to satisfy about upsells and minimum charges etc,,,over the customers actual needs..get it???
Old Jun 13, 2010 | 02:49 PM
lextl2006's Avatar
how much will this cost
Old Jun 13, 2010 | 05:23 PM
Turbonut's Avatar
Depends on where you get it done, and the replacement part, OE part or aftermarket.
OE part:
44306-SDB-A00 ACURA TL L. DRIVESHAFT ASSY. 2006 TL $322.72 $242.04
Aftermarket:
Rock Auto for example
CARDONE SELECT Part # 664221 {New}Front Left
$49.89
Add an hour minimum for labor, independant $75.00, dealer $125.00
