Navigation Acting Up
Old Jul 21, 2012 | 09:42 PM
NeilsTL's Avatar
6th Gear
So just this week my navigation started acting up. When the car is on, the navigation screen is stuck on the intro screen and never gets to the screen where you have to press OK. The strange thing is that when the car is just turned on to accessories (not turned on, no fans, etc) I can get past the screen where you press the OK button and then it shows a map. When you do this, the map shows up but it does not show the correct location.
Every once and a while when taking a drive, the navigation will work and the location is correct.
Any guesses on what is going on?
Old Jul 21, 2012 | 09:43 PM
NeilsTL's Avatar
6th Gear
I forgot to mention, its a 2006 TL...
Old Jul 22, 2012 | 12:00 AM
Will Y.'s Avatar
Registered but harmless
Originally Posted by NeilsTL
The strange thing is that when the car is just turned on to accessories (not turned on, no fans, etc) I can get past the screen where you press the OK button and then it shows a map...
It sounds like your Navi DVD unit is either dirty or going bad.
Pull the DVD out of the drive in the trunk and examine it for scoring/grooves.
There is a TSB on the DVD drive scoring the DVDs, ultimately causing Navi failure. If there is scoring on your Navi disc, the drive will have to be pulled and sent to an Alpine facility in Torrance, CA for repair; the cost of that repair is now @$360.
If there are no grooves or scoring on the DVD, try using a CD/DVD cleaner on the DVD drive. Another member partially disassembled his navi drive to do a gentle cleaning of the reader, which cured his Navi's problems without having to send the drive to Alpine.
G/L.
Old Jul 22, 2012 | 08:39 AM
NeilsTL's Avatar
6th Gear
Thanks for the reply. I'll see if I can find a cd/dvd cleaner today.
Old Jul 22, 2012 | 12:57 PM
swishersweep's Avatar
9th Gear
i have an 06 navi and when the navi speaks its just make like a wierd static sound the dealer told me to change the speaker for the navi but it doesnt work same thing.
Old Jul 23, 2012 | 12:52 PM
NeilsTL's Avatar
6th Gear
Unfortunately the disc cleaner did not work...
Old Jul 23, 2012 | 12:55 PM
SharksBreath's Avatar
BANNED
do you have a perfect circular scratch all the way around the face of the disc? if so, it's your nav drive failing and you'll need to send it to alpine or grow balls big enough to try and repair the mechanism yourself.
Old Sep 28, 2012 | 07:18 PM
NeilsTL's Avatar
6th Gear
The disk was OK. Just a quick update... after a fun filled month of moving... I ended up pulling the dvd unit out of the trunk and sending it to Alpine. They sent it back and I just installed it. Everything is working fine now. Too bad the Alipne price to fix it jumped to $358. I guess it beats buying a new DVD unit.
dirleton
Aug 6, 2024 08:19 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
TLguy42
Sep 26, 2015 11:27 AM
