Nav stays on day setting & mirrors don't adjust correctly
Just picked up a 2005 TL w/ Nav.
The day/night option for the display for Nav is set to auto but stays on daytime mode all the time(ie...it's bright all the time) Only if I switch it manually to night, will it go to night mode.
Also,
My drivers mirror always needs to be adjusted after backing up - seems as if after mirror angels down it does not come back to prior setting.
I plan to bring in for warranty. Just curious if anyone has had the same problems.
Also,
Welcome!
Originally Posted by xxxTL
The day/night option for the display for Nav is set to auto but stays on daytime mode all the time(ie...it's bright all the time) Only if I switch it manually to night, will it go to night mode...
Decrease your instrument panel brightness one notch or more below "Maximum" using the buttons on the bottom of the instrument panel. That will permit your Nav to switch modes automatically. Otherwise, the "Max" instrument panel light setting overrides the "night" mode of the Nav.
It sounds like a warranty issue if your outside mirror is not returning to the preset position after backing up. A search of the threads here will show that a couple or 3 people had repairs for clicking or grinding by the outside mirrors after changing from forward to reverse gear, or vice-versa. Not common, but has happened.
It worked. I can't believe I was driving at night like that. It was like driving w/ a flashlight shining in your face.
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
