My TL restoration
Old Oct 31, 2014 | 07:59 AM
mariusz439's Avatar
Smile My TL restoration
Hello. After months of waiting I finally have got may car that I dreamed of for some time. The 3rd gen TL-S
I start this thread to get some help from you as there are few things that bother me.
As I am perfectionist, I always want to have everything working in the right way.
Issues:
1. Leaking power steering hose – DONE
Hose fixed - thanks to AcuraZine and You Tube J
2. Noisy power steering pump - DONE
Pump renewed, power steering oil tank, tube & clamps changed.
3. Leaking oil – DONE
VTEC gasket changed.
4. Rear fog light – almost done
Trying different localization – now in back lights.
5. Rear lower arms – DONE
Changed.
6. Wasted tires – DONE
New one bought.
7. Engine side mounting and trany mounting – TO DO
8. Delay in changing gears – TO DO
I have read some threads. Almost all tracks to tranny oil and switches change. But they usually say about shifting between second & third and third & fourth gear while in my TL the delay exists while shifting any gear. It is slightly shorter in manual mode. I have dug through internet and I have found interesting thought that the delay may result from foulty injectors, fuel pressure. Any thoughts?
9. Both mirrors heating does not work. Switch works – TO DO
10. Driver’s seat heating. Seat cushion does not work while seat-back works. Switch works – TO DO
11. Passenger’s seat heating. Both seat cushion and seat-back does not work. Switch works – TO DO
12. Passenger’s seat side airbag. Both seat cushion and seat-back does not work – TO DO
13. Hi fuel consumption. 14MPG in city, 25MPG outside city. Probably sth wrong with lambda and AF ratio – TO DO
14. Missing rear cat – TO DO
15. "Tighten Fuel Cap" message. Purge control solenoid change – TO DO
16. Bluetooth is not working – TO DO
The wheel switches do not react. The module might be disconnected.
17. CD player – TO DO
Strange thing. CD player was working. While setting wheel alignment auto was raised. The machine for raising shaked the car for a while. After that cd stopped playing. The tape and radio works. When I switch to cd it tries to read but there is no sound. When I switch back to radio or tape it starts to play but bumps come every 3-4 seconds. The bumps while playing radio or tape stop only when I turn off ignition for longer time.
18. Bulbs under some buttons – TO DO
19. Some missing interior parts – TO DO
20. A-spec body – TO DO
Parts are waiting for springtime
21. Remote window roll-up – TO DO
Really strange this functionality is missing… as well as RDS in radio J
Funny thing is it is really difficult to buy sth from dealers in US when you want to ship it to Europe. Antifraud procedures are to strict J
One question. Key lock in steering column. There should rubber or sth round it. It is marked as 5 on combination switch diagram but there is no part number. Are those parts available?
Old Oct 31, 2014 | 08:33 AM
RedRyder's Avatar
Be a better driver
Congrats on the car. Looks like you have your work cut out for you, good luck with everything.
Old Oct 31, 2014 | 08:46 AM
kocyk123's Avatar
Hi Mariusz,
Cograts on your pick. First of all, tell me where are the Type-S rims huh? :P How many miles on the car? Lol I never noticed missing RDS in my car but I actually never turned it on. Not even once! I only listen to XM, CD and AUX FYI if you get XM it will show artist information Good luck on your To Do list!
Old Oct 31, 2014 | 08:50 AM
kocyk123's Avatar
Sorry for spamming.
I just wanted to say WOW there is no RDS in our car lol I took a better look at my radio and there is not RDS label.... What a shame! My 1996 Audi A6Quattro as well as 2001 A8L have it
Here is the picture if you want to take a closer look at the radio...
https://cimg2.ibsrv.net/gimg/acurazi...8d68b5db37.jpg
Old Oct 31, 2014 | 09:14 AM
ggesq's Avatar
is your car a salvage title?
Old Oct 31, 2014 | 04:51 PM
truonghthe's Avatar
welcome and congrats.
Old Oct 31, 2014 | 07:42 PM
nokkieny's Avatar
jeeeez, hope you got a really good deal, what is sth?
Old Nov 1, 2014 | 08:11 AM
PhobosTL's Avatar
I don't think the passenger seat back has heat. Correct me if I'm wrong.
Old Nov 1, 2014 | 08:23 AM
ggesq's Avatar
It does not.
Old Nov 1, 2014 | 08:56 AM
mariusz439's Avatar
My TL restoration
I am also wondering where those rims are I've bought it on insurance auction - probably this is root cause why some staff is missing.
This is winter set-up. I will thing about summer one in the spring. The millage is 115K.
The car is in Poland. Unfortunately there are no satellites transmitting XM on the sky in this side of globe.
Yes it was. Do you recognize it? I tried to find previous owner with no success.
Originally Posted by nokkieny
what is sth?
something
I look carefully at part details and wow - you are right. Front right seat parts diagram lists only cushion heater. I am shocked again (like when I realized there is no rds on radio) - driver has heater in cushion and back whereas passenger only in cushion - really strange, I've never seen such approach.
Old Nov 1, 2014 | 09:14 AM
truonghthe's Avatar
Interesting you are from Poland not too many people know about the TL over there never mind about the type s.
Old Nov 1, 2014 | 11:48 AM
kocyk123's Avatar
Wow that is cool! It is really unique car in Poland since they don't carry Acuras unless its an import. How are you going to deal with maintenance?
Old Nov 1, 2014 | 01:35 PM
main70072's Avatar
Remote window roll-up does not exist from factory. You can only roll down with the remote.
Old Nov 2, 2014 | 08:22 AM
mariusz439's Avatar
There is about up to 5 pieces of TL-S here Standard TL is more popular
I know a little bit about car maintenance. I have my trusted garage specialized in hondas that took care about my previous car, that was also rare in Poland when I bought it. Some parts are the same as in honda. The rest would be supplied from US. To be honest buying staff in US and importing it to Poland is much cheaper than buying it from Polish dealers. Prices here are ridiculous - example: two rubber o-rings for Power Steering Pump cost at Acura dealer in US about 1$ - same o-rings at Honda dealer here in Poland are 10$.
I know that - that's why I'm gonna get additional stuff
Old Nov 2, 2014 | 09:31 AM
guitarplayer16's Avatar
Here in Canada too.
Although when I'm looking at something that's cheaper than $20, I usually just buy it at the dealership anyway so I don't have to pay shipping and it comes in quickly.
Old Nov 2, 2014 | 04:02 PM
TacoBello's Avatar
Czeszcz, Mariusz!
Gdzie w Polsce mieszkasz?
Old Nov 3, 2014 | 06:58 AM
kocyk123's Avatar
Ja mieszkam w Jasle na podkarpaciu a wy?
Old Nov 3, 2014 | 01:04 PM
mariusz439's Avatar
Czeszcz, Mariusz!
Gdańsk
Ja mieszkam w Jasle na podkarpaciu a wy? :wink:
Tak właśnie coś mi Twój nick podchodził pod krajana
Guys - Torque indicate problems with O2 Heater. Problem for me is that it indicates Bank 4 - Sensor 4. Only thing that comes on my mind is that Torque gives the following numbers of sensors and Bank 4 Sensor 4 means Bank 2 sensor 2 in Acura.
What do you thing about that?
I am preparing to have large parts order - it would be nice to have right sensor for replacement.
Old Nov 3, 2014 | 01:08 PM
TacoBello's Avatar
Gdańsk
W Kanadzie
Old Nov 3, 2014 | 01:10 PM
mariusz439's Avatar
One more thing. Torque shows problems with O2 sensor while CEL does not come on. That makes me think previous owner might play with wiring and cheating ECU. Any advice how can I check it?
Old Nov 3, 2014 | 01:40 PM
6mt4tw's Avatar
Pass seat does not have heat element up top to protect the air bag and sensors is the official reason Honda didn't put one up top in passenger seat. I don't know why driver's seat has lower and upper then...
Take your key and put it in the cylinder @ the steering clumn. Turn it two times forward without starting the car. Does the check engine light come on? If not, someone removed it or covered it so you won't see it.
Old Nov 3, 2014 | 01:58 PM
truonghthe's Avatar
looks like someone already removed the bulb for the CEL.
Old Nov 3, 2014 | 03:26 PM
kocyk123's Avatar
I wish I had mine Acura in Poland Well, since you live there and you have pretty dark tints, don't you have any problems with cops? I know that they are fu**ing assholes about that...
Old Nov 3, 2014 | 06:34 PM
iHeartmyHonda's Avatar
Witam! Zajebista fura na polskie drogi! Ja mieszkam w kanadzie, ale urodzilem sie w plocku. Tez ma TL is tez ma swoje problemy. masz duzo roboty przed soba. good luck
Old Nov 3, 2014 | 07:27 PM
pohljm's Avatar
I would address the transmission issue asap. switches and fluid at a minimum
Old Nov 4, 2014 | 03:58 AM
mariusz439's Avatar
Sorry, I've put it in wrong words. My CEL works fine - it comes on when I turn the ignition on. I've meant that the CEL does not indicate any error while Torque Pro - each time I put it in diagnostic mode - show that O2 sensor does not meet voltage standard.
I know that one can cheat ECU with resistor or something - I am wondering what is the easiest way to check whether previous owner messed with it.
So far so good Nobody noticed since 2 months - even when police car was next to me. Probably it results from the fact that rear are much darker then front side ones.
On the other hand I have not been stopped for car check so far
It is on my list. I am going to visit my garage this week to have car checked for leakages. And next week I am ordering parts. Wish they would be here in the end of month.
Dzięki - mam nadzieję, że mi odrobinę pomożecie
Old Jun 13, 2020 | 02:41 AM
mariusz439's Avatar
A little update after 6 years 🙂
To​To be honest​honest ​​​I really enjoy this car.
1-12, 14-16, 18-20 done.
My mechanic recently said he tought I have changed the mechanic - I am rare visitor at his place.
Old Jun 13, 2020 | 09:56 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Post some pictures!
Hud
Nov 13, 2018 06:48 AM
JPerkMr954
Oct 13, 2014 12:03 PM
Royced
Nov 23, 2012 11:47 AM
DeathtoToasters
Aug 19, 2005 04:12 PM
