Is my clutch slipping? 2005 Acura TL 6mt
I drive it daily 124k, father don't beat on it by any means, changes gears flawlessly pedal has pressure, takes off with ease, but it started doing this yesterday out of nowhere just trying to pass a car in 5th gear barely going 45 to 55 to get by. No bad smells etc.
If you're in 5th gear and try and accelerate and the tach rises but your speed does not, then yes, you need a clutch. I bought my 2006 TL 6MT with 114,000 miles on it; the original owner was apparently an older individual who didn't beat on it either, and yet the clutch was already starting to slip if I shifted from say, 3rd to 4th at high power levels. Fortunately I rarely need to use that kind of power and I was able to baby the clutch for almost 20,000 miles before I finally replaced it.
Luk is the OEM manufacture for our clutches.
the fact is; these cars are so hard to learn or master the clutch. you dont have to beat on it to destroy the clutch
1st gear is probably where people burn up the clutch the most...
yeah, it's not your average system, also I'm guessing it's the original clutch from new off the lot. One owner before me all CARFAX and nothing about a new clutch. 🤷♂️ Wel boys fuck me running
I bought my TL at 30k miles and by 35k it was slipping pretty bad.
had a mechanic change it and I was good to go..
Not a fan of PartsGeek...
I bought mine from RockAuto:
From the "While you're in there" department (I did all of them and am glad I did; saves LOTS of money down the road):
- Clutch Kit: LuK #L08047 -- $185.99
- Dual Mass Flywheel: LuK DMF062 -- $216.99
- All three motor mounts
- All three transmission mounts
- Both axles
- Rear main seal
- Stabilizer bar bushings and end links
The following 4 users liked this post by horseshoez:
- Both axles
- Rear main seal
I had the same thing happen to me last year OP. Was attempting to go wot in 4th or 5th on the highway and was met with some major slippage. I hobbled the car around for another few months until I could get all the parts together for the job.
Slpr04UA6 (10-15-2020)
- Both axles
- Rear main seal (one big seal and an o-ring behind the plate)
- Lower ball joints.
- LCA bushing if it busted.
- Use OEM release bearing and pilot bearing.
There I added some extra item horsey might missed.
The following 2 users liked this post by truonghthe:
horseshoez (10-15-2020),
nist7 (10-22-2020)
Replacing the flywheel when you do the clutch is MANDATORY. Take that from 1st hand experience!
LUK tech support recommends this due to the way this dual-mass flywheel wears since this flywheel can't be resurfaced.
nist7 (10-30-2020)
[QUOTE=horseshoez;16642832]Not a fan of PartsGeek...
This is for a 2008 correct? I'm seeing a DMF105 for a 2008 type s 6mt, is the DMF062 for 04-06?
[QUOTE=jeffstlnote;16649886]
The 3.2 and 3.5 engines take different flywheels, but the same clutch kit.
Pass on PartsGeek, go Rockauto!
horseshoez (12-18-2020)
Wanting to do this!
Clutch
https://www.rockauto.com/en/moreinfo...440495&jsn=260
Flywheel
https://www.rockauto.com/en/moreinfo...440495&jsn=262
Bearing
https://www.oemacuraparts.com/oem-pa...se-22810ppt003
I've read not using the Luk bearing and going with OEM is the best call. Anything I'm missing?
Clutch
Flywheel
Bearing
Bearing https://www.oemacuraparts.com/oem-pa...se-22810ppt003
And don't forget to replace the Flywheel too!
Certainly eases the mind, and would save roughly $60, I think this was the video that had me thinking about the bearing...
https://www.youtube.com/watch?v=y9aoc6jBmTo&t=163s
If you're using all OEM parts, disregard the video.
I posted that video because it was the first of 2 maybe 3 videos where the person making it stated they were not going to use the LuK bearing. Nothing to do with the flywheel. When I do this replacement I will 100% be using the Luk DMF105 for my Type S. But now I have guys saying the bearing that comes from Luk in the kit is OEM. I just want to use OEM all around, t's $56 roughly from Acura, but if the Luk is honestly the SAME then I'd use it.
The video you posted used an aftermarket flywheel, which you aren't using. So disregard the video
