Experimental fix -- sliding cupholder cover
Old Dec 9, 2020 | 09:37 PM
Hyperblu's Avatar
Attached adhesive backed felt to the underside of an intact cupholder slider in hope the tensile force would be applied evenly across ALL ribs instead of the first few.
LINK TO FELT:
https://www.amazon.com/Pllieay-Adhesive-Polyester-Furniture-Surfaces/dp/B07CPN1WRS/ref=mp_s_a_1_4?dchild=1&keywords=adhesive+backed+f elt&qid=1607570120&sr=8-4
Old Dec 10, 2020 | 12:04 PM
PaulK3's Avatar
Seems like a very good solution. Have you installed & used it yet ? If so, does the felt easily slide ?
Old Dec 11, 2020 | 03:02 AM
mariusz439's Avatar
Have tried the similar solution but with mount tape. The problem is those materials are stretching a little but enough to let the cover sticks to go apart after several slides. Good luck.
Old Dec 13, 2020 | 11:01 PM
Wdp_3g's Avatar
Looks good. I used duck tape on mine after replacing 4 times and it's been doing fine for a few months now as long as you push it together tight you can't see the cracks.
Old Dec 18, 2020 | 11:53 AM
Adobeman's Avatar
The DVD-A Script Guy
Similar to fix I did but I resisted using anything with a tape-like adhesive. My fear was those would get gummy in the heat over time, fail and be a mess to fix. So I used some cloth and cyanoacrylate glue (Krazy Glue) to bond the cloth to the underside of the cover. Practically speaking same as what you did. Realistically the cloth is thinner than felt and the bond should be more permanent and resistant to hot weather.
Old Dec 21, 2020 | 11:57 AM
Synchro's Avatar
Has anyone tried Flex Seal?
Virginia Donkey
1G RL (1996-2004)
Apr 27, 2007 02:37 PM
Chief F1 Fan
Oct 25, 2006 09:28 PM
J.T.'s 3.2CL
Nov 25, 2003 05:19 AM
