My 6MT stucks at 3rd gear very often.
zero to biotch:3.0s
I just wanna say, OEM transmission fluid sucks as hell. I was trying to upshift to 3rd yesterday and gear didn't go all the way, and i missed the gear eventually. this is not the first time. It happened several occasions and it drives me nut! any transmission oil recommendation?
The DVD-A Script Guy
Wow. 144 posts and you're unaware of one of the most documented issues with the 6MT ?
"GM Synchromesh Manual Transmission Fluid, Friction Modified" is all you need to know.
Search it and you will see much dialog on this very topic. Type 'friction modified' into the search of this forum and you'll be busy for hours reading it all.
PCM full of water, yummy
zero to biotch:3.0s
Originally Posted by blokhead
What he said.. Works like a champ
zero to biotch:3.0s
3rd gear pisses me off now. i'm gonna set for apointment to change transmission oil to GM Synchro. what's the price go for parts and service?
3 quarts of GM synchromeshshould be about $33 or so. Labor, don't know, did it myself in about 30 minutes, so figure $80/hr at the dealer, you should be into it for $80 or so. Good luck.
All,
Just wanted to let you know I finally had a success with Acura on the ongoing third gear issue. I complained about the 3rd gear issue umteen times and finally today after having new synchros, a new tranny, and an exorbitant amount of time with my car in the shop my service guy told me that Acura is awar of the issue and is planning on putting out a fix for it somewhere around the feb 08 timeframe. I dont know about you but they finally owned up to the issue and I am planning on writing to Acura on this issue as they have obviously known about it since the 04 model came out. THey guy said oh since you car probably will be out of warranty by the time it comes out they will honor the repair. Just thought you may like to know there is a little hope at the end of the 3rd gear tunnel..
Thats music to my ears!!! I was considering changing to the GM fluid but didn't want to deal with warranty issues. I really hope that they fess up and fix this tranny problem. I was starting to feel like I was going to have to get synchros changed like I change my oil
Originally Posted by cawad
All,
Simple economics would seem to favor them trying a new MTF again instead of ripping apart 2 or 3 year old MTs. Sure, put a physical fix into the production line but I don't see them spending all the warranty budget when customers can be satisfied by a <$30 fix (new MTF). It's not like MTs with the GM stuff are disintegrating. Just seems that most folks that resist the GM fluid only do so because it doesn't say "Acura" on it.
Nonetheless I'm still open minded to hear what they say the fix is.
SidhuSaaB
05-30-2020 12:40 AM
guyvelella
09-30-2015 11:02 PM
