Mt on '04 TL hard to shift. Help!!
^well, I believe what he is trying to say is that the clutch pedal sticks after a hard RPM run.
I experienced this.
and tried a lot of remedies.
the only one that worked was changing out the clutch.
I believe this feeling was attributed to the pressure plate.
I experienced this.
ez12a might be right, please check the master cylinder to see if your fluid is topped off.
I would check the clutch fluid. If it's low, there is most likely a leak. After more research, it seems either or both slave and master cyl can cause a limp pedal.
dromega37 (07-20-2012)
SidhuSaaB
05-30-2020 12:40 AM
mlody
12-04-2019 02:11 PM
