Motor and Trans. mounts question
Old Jun 8, 2023 | 02:47 PM
robster80's Avatar
Stick to OEM on ALL 5 mounts? (07 type s). All 5 are gonna run me a grand , which would be fine if i didnt have a ton of other expensive maintenance to do. Can u get by with replacing any of the mounts with aftermarket mounts and not have vibration?
Old Jun 12, 2023 | 08:20 AM
Zargs's Avatar
Motor and tyranny mounts.
I recommend going with oem mounts. The cost might be more but they will last longer and not having to change the aftermarket ones twice in the same time the oem ones would still be going strong more then makes the initial cost worth it. The transmission mounts are a bitch to do. The back lower one calls for dropping the sub frame but if you take a grinder to the little nubs on the bolts that have no thread you can get it in. Good luck.
timbo7
Apr 9, 2025 02:31 PM
kpayne111
Aug 13, 2020 09:36 AM
kfalisi
Jun 30, 2017 09:21 PM
XxAfG786xX
Jun 29, 2012 07:47 AM
sjefferson
2G CL Transmission Recall Q & A
Oct 20, 2006 09:59 AM
