Motor ticking
Motor ticking
Whats the likelihood of valves needing to be adjusted on an (07) automatic tl with 67k? I'm getting a ticking that varies with engine speed and is present when cold and warm. Sounds to me louder than injectors. I took the plastic covers off to try to hear where it's coming from, but can't really tell.
Resident Dingo
Unlikely, but not impossible. Just about every TL I've been around has the slight lifter tick sound. Even when valve adjustments are within spec. I wouldn't worry about it unless it gets louder. However, if you're going to lose sleep over it, have a competent mechanic ensure that you're all set.
Where you located in Virginia?
I took my TL to the dealer for the same problem it ended up being a loose spark plug it ruined my coil pack and everything i got the plugs and the coil pack changed and no more ticking car only has 72000 on it
Just checked the spark plugs and the front pass side spark plug was somewhat loose. I tightened it and still have the noise. It almost sounds like a motor with low or barely any oil but there is plenty in it. I can hear it from about 20ft away. I worked on a 04 accord coupev6 this am and I popped the hood to hear the motor and it is damn near silent
Received 3,824 Likes
I have the same thing in the mornings, and when the car has been sitting for a while. Sometimes it's loud, and other times it's not. I could never really find an answer to this.
Also, tried using an automotive stethoscope and couldn't really pinpoint where the source was. I did touch it to the coils and the nuts for them and it seemed to get less noisy the farther away from the pass side I got. I could hear it when touched to timing belt covers, valve covers, cylinder head, pretty much everything.
It doesn't go away when warm or above certain rpms, it's always present. I pulled the butterfly for the i.m. and it had slight play to it but I suspect that's the tiny bit of room between the teeth on the gears for it.
Two things I haven't checked are:
-valve clearance
-tensioner and pulley for timing belt
-valve clearance
problem solved:
dropped it off at wallace automotive and they called me shortly to say it needed valve adjustment. A few valves were way out of spec and they fixed it and put it back together. Noise was still present. Then they thought I bent/tweaked a valve so they were gonna pull the heads. Before doing that, they found a loose bolt on a rocker arm and that is what was making the noise.
Jamus22
06-11-2023 10:08 AM
xsilverhawkx
09-28-2015 06:51 PM
