Motor Assembly, Drive Air Mix
Old Nov 27, 2018 | 11:39 AM
DMZ's Avatar
DMZ
Head a da Family
Acura part # 79166-SEP-A02. That little motor that controls opening and closing of the heater valve via a little cable.
All the on-line dealers want around $250!
Any suggestions gang?
Old Nov 27, 2018 | 11:50 AM
When I tried to buy in 2015, discontinued or no ETA available... i ended up just grabbing one from the junk yard....only 4 years later it has failed again... this time; instead of replacing, I'll try to clean the contacts, as that's what makes it stop working in the first place.
Old Nov 27, 2018 | 12:09 PM
junkyard
Old Nov 27, 2018 | 01:13 PM
DMZ's Avatar
DMZ
Head a da Family
junkyard
My thoughts exactly!
Tanksh!
Old Nov 27, 2018 | 09:00 PM
nfnsquared's Avatar
Are you sure it's the motor and not the valve itself or the cable?
Old Nov 28, 2018 | 01:26 PM
DMZ's Avatar
DMZ
Head a da Family
Which contacts specifically?
Old Nov 28, 2018 | 01:47 PM
redbeard1's Avatar
I've circled the areas to clean.
This DIY is for 2g but the motor is pretty similar to 3g.
https://acurazine.com/forums/second-...repair-848488/
Old Nov 28, 2018 | 03:21 PM
DMZ's Avatar
DMZ
Head a da Family
Certified by Paul, our star master mechanic here in Northern NJ
Old Dec 6, 2018 | 06:13 PM
DMZ's Avatar
DMZ
Head a da Family
Paul, our star master mechanic in Northern NJ to the rescue! He took it apart, cleaned the contacts as described above, and WOLA! The heat works perfectly again!
Anyone in the NYC/NJ area are who needs work done on a Honda or Acura should call him, 201-562-8576. Tell him Tony Soprano shent ya!
Skirmich
Mar 17, 2025 07:50 AM
SweetBabboo9713
Jun 15, 2014 04:32 PM
chris03tl
Mar 27, 2012 07:22 PM
9932
Aug 24, 2009 12:39 PM
tmcnamee
Oct 26, 2006 06:05 PM
