Moisture in Head Lights
Old Feb 19, 2011 | 09:01 PM
BobbyGlide's Avatar
6th Gear
I have moisture in my 06 Tl head lights. How do I get rid off the moisture and how do I prevent this from happening?
Rob
Old Feb 19, 2011 | 10:23 PM
Bearcat94's Avatar
AZ Community Team
Have they ever been opened? Like to black out or clear them?
Old Feb 20, 2011 | 01:03 AM
bigtymin418's Avatar
6th Gear
I've had this happen to me today. It never rains in phoenix but it has been all day today. I notice moisture when i run the car through the car wash. Tonight the lighting on the headlamp that gets the moisture buildup went out and is not working. I guess I'm going to check tomorrow once it dries out to see if the electrical stuff is bad now.
Any suggestions on what do to now?
Old Feb 20, 2011 | 05:46 AM
csmeance's Avatar
Disconnect the battery before touching the headlights in the TL! The HID's send upwards of 1,000 volts to ignite the HID system and can really give a jump-start to the person touching them.
Condensation can occur if a seal is broken on the headlight:
1. Outer seal around the headlight
2. Seals on the turn signals
3. Seal on the DRL/Fog light bulb
4. Seal on the HID cap/system
The best thing to do is try turning on the headlight after a few days of letting it all dry out. Then if it doesn't turn on try ripping into it to see what is going on. If it does work, take a look at the headlight and make sure there are no cracks along the edge. As well, take a look at all the bulbs and make sure they are properly locked in place with the seals making good contact.
Feb 25, 2020 09:57 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
BigJilm
Sep 21, 2015 08:32 PM
PortlandRL
Sep 14, 2015 12:01 PM
Ny1718
Sep 11, 2015 09:21 AM
