Mirrors
Old Jun 9, 2020 | 08:49 AM
Ted Kief's Avatar
Mirrors
The mirrows on my 2008 TL are moving randomly what fuse do I remove to disable them.
Old Jun 9, 2020 | 09:14 AM
vpasla1's Avatar
You can unlink your remote, make sure your mirror switch isn't left on one side, or to fix the issue, replace your mirror actuators.
Old Jun 9, 2020 | 03:32 PM
pohljm's Avatar
when does the random movement take place? when you shift into R? both mirrors or just one?
Old Jun 9, 2020 | 04:03 PM
Replace the actuators, it's a common issue
Old Jun 10, 2020 | 09:37 AM
Ted Kief's Avatar
Both mirrows It happens when I open the door
Old Jun 10, 2020 | 10:38 AM
peter6's Avatar
Car wants to apply the memory seat profile when you open the doors, and that include mirror position.
Since potentiometers inside the mirrors went bad car has no feedback of mirror position so they go all the way and start clicking.
Like others wrote - common issue.
OEM actuators cost ~$40 each + tax + shipping. Hardest part is getting mirror off the actuator.
Here are all the fuses used by mirror control unit. Chances are they are also used for other things, so taking them out might disable other systems.
If you really want to go for $0 solution I would disconnect both actuators inside the mirrors instead of taking fuses out.
Old Jun 10, 2020 | 11:50 AM
PhysicalGraffiti's Avatar
8th Gear
Have this same problem and glad I searched.
https://www.acurapartswarehouse.com/...0-stx-h03.html
Is that the part I need?
Thanks.
Old Jun 10, 2020 | 12:53 PM
Jackass's Avatar
Yes that is the correct part.
Good reference thread
Old Jun 10, 2020 | 09:35 PM
8th Gear
Perfect thanks! Ordering the part now.
Old Jun 11, 2020 | 07:53 AM
Ted Kief's Avatar
Thanks,I will disconnect them.
silverTL6
Sep 28, 2014 08:20 AM
Tonman23
2G CL Problems & Fixes
17
Sep 29, 2009 09:58 PM
InFaMouSLink
Jul 29, 2009 11:12 AM
Zapata
Aug 21, 2001 08:19 PM
kmanpete
May 11, 2001 01:55 AM
